Posted August 22, 200618 yr Know how much hard drive space you have left at a glance, just like in windows vista.Installation is easy...Just extract the contents of this .rar file into your program files folder and run the .exe file.Windows Defender Users:When you run the .exe file, Windows Defender will pop up, accept the changes and its business as usual http://www.wincert.net/forum/index.php?showtopic=1273Thanks to Kelsenellenelvian for this great addon
August 22, 200618 yr Even drive icons are changed to Vista style. Nice add-on and very useful too If you wan't to revert to default settings you should do this:Start --> Run This will fix it back to default:REG Delete HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\DriveIcons /fThis will remove all customized icons on the drives and set them back to default icons inside the shell32.dll (may require refresh F5, or just quit My Computer and run it again).
August 22, 200618 yr good stuff! :thumbsup_anim: :tired: theres my laptopPlease rehost you image--WolfX2
October 29, 200618 yr If you want one with more capabilities, check out WinDirStatWinDirStat is a disk usage statistics viewer and cleanup tool for Microsoft Windows (all current variants).
March 26, 200718 yr Just tried this and now i have no drive icons You've probably run it from the temp folder while the files were in .rarFirst extract contents of the rar file in some folder, for example C:\Program Files\Vista Drive Indicatior and run the exe file from there.You shouldn't have problem after that..
March 26, 200718 yr Try installing Kels Vista Drive AddOn manuallyhttp://www.wincert.net/forum/index.php?showtopic=1393Uncompress to subfolder and right click on the .INF fileSelect InstallBrowse to the .CAB archive and hit open then OKNow reboot and see it that helped
March 27, 200718 yr You could have also used TweakUI to rebuild your Icon cache OH and don't forget to remove any startup reg entries of the old Vista Drive Indicator and any of its program files
October 5, 200717 yr Try installing Kels Vista Drive AddOn manuallyhttp://www.wincert.net/forum/index.php?showtopic=1393Uncompress to subfolder and right click on the .INF fileSelect InstallBrowse to the .CAB archive and hit open then OKNow reboot and see it that helpedSorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.Where is the files?
October 5, 200717 yr http://www.wincert.net/forum/index.php?showtopic=1273 <------- Goto this thread there is a pre made silent installer with the updated addons...
