Posted November 24, 201410 yr Just wondering per say because with say simplix update pack once you integrate the LP's you get the dreaded offline LP error which only seem to happen once you slap together x86 w/ x64.
November 25, 201410 yr I think it actually has to do with the final wim size. The wims this way tend to be well over four gigs. That might be the problem
November 26, 201410 yr Author So compressing to esd might be a good idea? Question is though because my x64 AIO ML is well over 5,7GB
November 27, 201410 yr I don't know if you could compress below 4 gigs. You could have the toolkit separate it into 2 swm files though that might be a better idea.
November 27, 201410 yr Author Good news! I have come to the conclusion that it comes down to updates that somehow clash together (even possible?), as I stripped it down to just Pro and HP. I will look into this further as I really need the wim to be below 5,5GB due to constriction of our flash drives at work (16GB) that are filled with other distros and such. edit: seems that WHD was the culprit on how it integrated it's language packs (got broken after AIO x64+x86). All well now thanks to WTK Edited December 5, 201410 yr by Nessaja
