Posted December 2, 201410 yr Hi all, just simple question can i remove the key in RunOnce :[HKEY_LOCAL_MACHINE\test\Microsoft\Windows\CurrentVersion\RunOnce]"1WinToolkit"="WinToolkitRunOnce.exe"because i dont use it and in the first logon i have a strange vbs file appeared from nowhere???
January 14, 201510 yr There is a settings in options to disable adding it in the first place this option doesn't work. I disabled this option, in AIO Integrator added only tweaks, but key and file WinToolkitRunOnce.exe was added Edited January 14, 201510 yr by XTriLogy
January 19, 201510 yr I shall have a look at the option before I release an updated version tomorrow.
January 23, 201510 yr this option doesn't work. I disabled this option, in AIO Integrator added only tweaks, but key and file WinToolkitRunOnce.exe was added in new version too
