I run WinToolKit 1.5.3.5 in VMware Player 7 and have used WHDownloader to get all updates.
When I setup all updates, gadgets, themes and Silent Installers all is okay...no load errors.
During AIO use I have some updates with Green and Yellow Checkmarks, one is Black
Using Portable Version and Win7 x64 +SP1 OS.
X.Last Sessions.zipLogs.zipSettings.zip
Third Try, No luck.
Thanks for some help.
Sincerely, Db_certdism.7z
Edited by db_cert
Why do you run WinToolkit within VMWare Player?
I run WinToolKit 1.5.3.5 in VMWare because it is a generally cleaner OS environment than my Host OS (which has problems with some missing files and manifests in c:\windows\winsxs).
Also I would need a screenshot as you haven't really specified what it hangs on or what you just did before it hangs :)
I use a virgin OEM version of Win7x64 with updates provided by WH Downloader 0.10 with all Windows 7 x64 downloads for Home Users - nothing else. I start the Integration, it progesses then balks with a Warning Box saying something went wrong and there was no point to continue. This happens when a Language Pack is integrated). Only use English US here.
Please answer the question on what the colored checkboxes mean, also.
Thanks for helping, Don
Edited by db_cert
