DougSchuess Posted December 22, 2014 Posted December 22, 2014 Is there a way to set the sefault TimeZone with WTK? I am thinking putting something like the following in SilentInstaller (RunOnce) via a command file that has been converted to an SFX:: DISM /image:<MountName> /Set-TimeZone:<TimeZoneName> If my idea seems feasible, what MountName should be used?DISM documentation says that any value contained in HKLM\Software\Microsoft\Windows NT\CurrentVersion\TimeZone can be used in <TimeZoneName>. Quote
Snow Posted December 23, 2014 Posted December 23, 2014 Do it with Autounattend.xml and place it in the root of your Windows DVD. Example for German : <?xml version="1.0" encoding="utf-8"?><!--Created by Win Toolkit v1.4.0.75--><unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="windowsPE"> <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="NonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SetupUILanguage> <UILanguage>de-DE</UILanguage> </SetupUILanguage> <InputLocale>0407:00000407</InputLocale> <UserLocale>de-DE</UserLocale> <UILanguage>de-DE</UILanguage> <SystemLocale>de-DE</SystemLocale> </component> <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="NonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SetupUILanguage> <UILanguage>de-DE</UILanguage> </SetupUILanguage> <InputLocale>0407:00000407</InputLocale> <UserLocale>de-DE</UserLocale> <UILanguage>de-DE</UILanguage> <SystemLocale>de-DE</SystemLocale> </component> </settings></unattend> Quote
DougSchuess Posted February 13, 2015 Author Posted February 13, 2015 If autounattend.xml is present, the resulting install files can not be used for repair; the install process begins without presenting that option. Quote
