Wim manager error to emport image
Title: Error
ErrType: Error
Description: An error occured whilst trying to export an image.
Exception:
ImageX Tool for Windows
Copyright © Microsoft Corp. All rights reserved.
Version: 6.2.9200.16384
IMAGEX [FLAGS] /EXPORT src_file src_number | src_name dest_file dest_name
Exports a copy of the specified image to another WIM file.
  src_file - The path of the WIM file that contains the image to be copied.
  src_number - The number that identifies the image within the source WIM.
  src_name - The name that identifies the image within the source WIM.
  dest_file - The path of the WIM file that will receive the image copy.
  dest_name - The unique name for the image in the destination WIM.
Accepted FLAGS:
  /BOOT
  Marks a volume image as bootable. Available for Windows PE images only.
  /CHECK
  Enables WIM integrity checking. If not provided, existing checks are removed.
  /COMPRESS [maximum | fast | none]
  Specifies the type of compression used when exporting to a new WIM file.
  /REF splitwim2.swm
  Enables the reference of split WIM (SWM) files.
  splitwim2.swm - Path to additional split file(s). Wild cards are accepted.
  /TEMP
  Specifies the path where temporary files are stored.
Comments:
  If src_name is "*" then all images are exported to dest_file.
Example:
  imagex /export d:\imaging\data.wim 1 d:\imaging\newfile.wim "Exported Image"
