Tuesday 23 December 2014 12:31:28 PM -08:00 Pacific Standard Time
Log ID: UxD668A1C4103AE182133E4C79D6E37D24_Ex060024AA_frmToolsManager_en-US_927382
NOTE: Use the 'Log ID' when referring to your issue on the forum.
It will allow me to find your log and have a look at the problem easier.
***TITLE***
Unknown Error
***BASIC***
A major unhandled error has occurred. A log should have been written and uploaded.
***EXCEPTION***
String was not recognized as a valid DateTime.
InnerException:
Source: mscorlib
TargetSite: System.DateTime Parse(System.String, System.Globalization.DateTimeFormatInfo, System.Globalization.DateTimeStyles)
***WINTOOLKIT INFO***
Win Toolkit v1.5.3.8
Win Toolkit Directory: D:\Slipstream\Programs\WinToolKit
Anti-Virus: False
User Temp Path: C:\Windows\WinToolkit_Temp
WTK Temp Path: C:\Windows\WinToolkit_Temp
Open Forms: frmToolsManager
Form History: frmStartup, frmToolsManager
***COMPUTER INFO***
Computer Name: BUCKWHEAT
System Directory: C:\Windows\system32
DISM Latest: C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe _ 6.3.9600.16384
DISM Default: C:\Windows\System32\Dism.exe _ 6.1.7600.16385
Microsoft Windows NT 6.1.7601 Service Pack 1 (en-US)
Windows 7 Professional (64-bit)
7601.22736.amd64fre.win7sp1_ldr.140706-1507
Resolution: W 1400 H 1050 D 16
CPU:
Name- Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
Speed- 2661Mhz / 2661Mhz
Cores- 4 / 8
Status- 2% OK
Physical Memory: 3,299 MB / 12,285 MB (8,986 MB Free)
Virtual Memory : 3,263 MB / 12,483 MB (9,220 MB Free)
Drives
C:\ Fix NTFS 156.07 GB / 238.37 GB SSD
D:\ Fix NTFS 658.83 GB / 1,863.01 GB Data
F:\ Fix NTFS 114.76 GB / 149.05 GB Recovery
***STATUS HISTORY***
Checking for updateCache.db update.
Loading Update Cache...
***PROCESSES***
Agile1pAgent [1Password] - 8.86 MB
Agile1pService [1Password] - 5.74 MB
allsnap [allSnap: makes all windows snap together] - 4.69 MB
allsnap64 [allSnap: makes all windows snap together] - 6.23 MB
AppleMobileDeviceService [MobileDeviceService] - 12.04 MB
armsvc [Adobe Acrobat Update Service] - 3.99 MB
BTSync [BitTorrent Sync] - 23.63 MB
CopyAgent [Copy Agent] - 74.67 MB
csrss [Client Server Runtime Process] - 5.36 MB
csrss [Client Server Runtime Process] - 8.96 MB
csrss [Client Server Runtime Process] - 13.45 MB
Dock64 [Dock64] - 6.78 MB
Dropbox [Dropbox] - 95.21 MB
dwm [Desktop Window Manager] - 6.22 MB
EEventManager [EEventManager Application] - 9.79 MB
explorer [Windows Explorer] - 60.20 MB
explorer [Windows Explorer] - 61.23 MB
explorer [Windows Explorer] - 92.11 MB
FUFAXRCV [Fax Reception] - 12.09 MB
FUFAXSTM [Fax Transmission] - 16.92 MB
GoogleCrashHandler [Google Crash Handler] - 1.65 MB
GoogleCrashHandler64 [Google Crash Handler] - 1.13 MB
GROOVE [Microsoft OneDrive for Business] - 45.07 MB
IdleiPodService [iPodService Module (64-bit)] - 7.11 MB
iTunesHelper [iTunesHelper] - 12.73 MB
jusched [Java(TM) Update Scheduler] - 4.96 MB
LMIGuardianSvc [LMIGuardianSvc] - 7.93 MB
LogMeIn [LogMeIn] - 22.47 MB
LogMeInSystray [LogMeIn Desktop Application] - 14.43 MB
LogonUI [Windows Logon User Interface Host] - 24.27 MB
lsass [Local Security Authority Process] - 13.83 MB
lsm [Local Session Manager Service] - 6.75 MB
mDNSResponder [Bonjour Service] - 6.18 MB
msiexec [Windows® installer] - 12.21 MB
MSOSYNC [Microsoft Office Document Cache] - 23.78 MB
mvmcP2VAgent [Microsoft Virtual Machine Converter P2V Agent] - 9.44 MB
nvvsvc [NVIDIA Driver Helper Service, Version 337.88] - 7.88 MB
nvvsvc [NVIDIA Driver Helper Service, Version 337.88] - 13.78 MB
nvwmi64 [NVIDIA WMI Provider Core] - 6.07 MB
nvwmi64 [NVIDIA WMI Provider Core] - 12.67 MB
nvxdsync [NVIDIA User Experience Driver Component] - 19.22 MB
ObjectDock [ObjectDock] - 26.20 MB
ObjectDockTray [ObjectDockTray] - 27.80 MB
PDAgent [PDAgent Module] - 26.32 MB
PDAgentS1 [PDAgentS1 Module] - 6.58 MB
PDEngine [PDEngine Module] - 17.02 MB
phraseexpress [PhraseExpress] - 37.82 MB
ramaint [LogMeIn Maintenance Service] - 5.80 MB
rdpclip [RDP Clip Monitor] - 7.80 MB
rusb3mon [USB 3.0 Monitor] - 5.63 MB
Samsung Magician [Samsung Magician Application] - 12.34 MB
SamsungRapidApp [Samsung RAPID Mode Notification Utility] - 5.09 MB
SamsungRapidSvc [Samsung RAPID Mode Service] - 3.10 MB
services [Services and Controller app] - 13.57 MB
smss [Windows Session Manager] - 1.39 MB
spoolsv [Spooler SubSystem App] - 14.88 MB
svchost [Host Process for Windows Services] - 19.54 MB
svchost [Host Process for Windows Services] - 20.16 MB
svchost [Host Process for Windows Services] - 35.32 MB
svchost [Host Process for Windows Services] - 6.11 MB
svchost [Host Process for Windows Services] - 17.45 MB
svchost [Host Process for Windows Services] - 11.79 MB
svchost [Host Process for Windows Services] - 5.40 MB
svchost [Host Process for Windows Services] - 6.63 MB
svchost [Host Process for Windows Services] - 11.11 MB
svchost [Host Process for Windows Services] - 10.48 MB
svchost [Host Process for Windows Services] - 35.15 MB
svchost [Host Process for Windows Services] - 51.93 MB
svchost [Host Process for Windows Services] - 6.13 MB
svchost [Host Process for Windows Services] - 18.80 MB
Systemtaskeng [Task Scheduler Engine] - 8.01 MB
taskhost [Host Process for Windows Tasks] - 12.76 MB
TrustedInstaller [Windows Modules Installer] - 14.48 MB
VCDDaemon [Virtual CloneDrive Daemon] - 5.60 MB
vmnat [VMware NAT Service] - 4.79 MB
vmnetdhcp [VMware VMnet DHCP service] - 10.37 MB
vmware-authd [VMware Authorization Service] - 9.60 MB
vmware-converter [VMware Converter Service] - 28.07 MB
vmware-converter [VMware Converter Service] - 33.06 MB
vmware-converter-a [VMware Converter Service] - 26.69 MB
vmware-hostd - 49.68 MB
vmware-tray [VMware Tray Process] - 5.43 MB
vmware-usbarbitrator64 [VMware USB Arbitration Service] - 8.52 MB
vpnagent [VPN Agent Service] - 13.97 MB
vpnui [Cisco AnyConnect User Interface] - 18.12 MB
VSSVC [Microsoft® Volume Shadow Copy Service] - 7.07 MB
WDBtnMgrSvc [WD Drive Manager Service] - 6.83 MB
WDBtnMgrUI [WD Drive Manager] - 9.28 MB
WindowsUpdateNotifier [WindowsUpdateNotifier] - 12.35 MB
wininit [Windows Start-Up Application] - 4.97 MB
winlogon [Windows Logon Application] - 7.59 MB
winlogon [Windows Logon Application] - 8.97 MB
WinToolkit [Win Toolkit] - 18.93 MB
WmiApSrv [WMI Performance Reverse Adapter] - 6.96 MB
WmiPrvSE [WMI Provider Host] - 7.48 MB
WmiPrvSE [WMI Provider Host] - 22.14 MB
wmpnetwk [Windows Media Player Network Sharing Service] - 9.82 MB
***OPTIONS***
sMountTemp=C:\WinToolkit_Mount
sAddRunOnce=True
sAICommands=True
sAVScan=True
sAIOSave=True
sUpdFilter=True
sPreventSleep=True
sCheckForUpdates=True
sDLogging=True
sDISMUpdate=True
sFreeRAM=True
sLastDir=C:\Users\clint.Buckwheat\Desktop
sDeleteMount=True
smCheck=False
sAIOPM=True
sQuickMerge=True
sFormSize=|frmAIODiskCreator:760*464|frmUpdCatalog:896*431
smVerify=False
sSolDownload=D:\Slipstream\Programs\WinToolKit\Updates\
sTransparency=100
sTransparencyAll=False
sWinToolkitDISM=Normal
sWinToolkitExt=Normal
sWinToolkitPRI=Normal
sUploadLogs=True
sMountLog=True
sShowWelcome=False
sRegistryLog=False
***STACK***
get_GetStackTrace
PrepareLog
Save
Upload
MyHandler
OnThreadException
WndProcException
Callback
System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop
RunMessageLoopInner
RunMessageLoop
Main
***RAW_EXCEPTION***
System.FormatException: String was not recognized as a valid DateTime.
at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles)
at WinToolkit.Classes.UpdateCache.Load()
at WinToolkit.frmToolsManager.cmdAIOI_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
