Hi Lego,
After I integrated things using the AIO integrator (wintoolkit v1.5.3.9), it asked me an unmount confirmation dialog. 'Save & rebuild' was disabled, so I clicked on 'Save'.And, after some time, it stopped responding!; i waited for about 20mins & still the same. So I decided to forcefully close it.
The wim was of win8.1 enterprise x64 (with update)
After that, the strange thing:
I opened WIM Manager, and I saw the same wim mounted, and was 10.xxGB. I just opened the mount location, and after 4-5mins, the mount disappeared, and there was only 2 folders: Windows>System32, and the system32 folder was empty. !!!  :blink:
I again checked the wim manager, and the mounted wim was still present! The arc now showing was x86 7 image name corrupted, build 0.0.0.0. !!!  :o
So, is my wim corrupted! Should I integrate again! All the logs & not responding screenshot is given as attachments.  :confused02:
Thanks
Logs.7z
Not Responding Image:
post-69983-0-58724100-1420132273_thumb.p
