Posted January 24, 201510 yr MiniTool Power Data Recovery Software Personal Edition is an excellent and flexible recovery program that can help you restore data from a wide variety of devices, including USB flash drives, Blu-ray Discs, DVDs, CDs, memory cards and more, when that data have been lost in a variety of ways, including accidental deletions, viruses, and partition alteration, damage or formatting. This file recovery software can restore all types of Windows files and supports IDE, SATA, SCSI and USB connections. The simple user interface is very friendly even for beginners and includes wizards which can guide you every step of the way so no training is required to operate the software. What's new in the latest version is the ability to handle drives with 4096 byte sectors. Please Note: No matter which tool you use to try to recover deleted or damaged data, the more you have continued to use the media the data is on after the data was lost, the more you risk overwriting the desired data to the point it can no longer be recovered by any tool at a reasonable cost. Power Data Recovery is an easy to use program. Once you start the program with its user-friendly interface, you then select one of five different recovery modules to use to start the recovery process: The 'Undelete Recovery' module can be used to recover any deleted files or folders even if they have been deleted from the recycle bin or otherwise "permanently deleted" from the computer. The 'Damaged Partition Recovery' module is the most powerful of the five recovery modules and recovers lost data from damaged partitions or recently formatted disks as long as the partition has not been deleted. The 'Lost Partition Recovery' modue specifically recovers data from partitions that are lost or have been accidentally deleted, such as what happens occasionally after reinstalling a Windows OS. The 'Digital Media Recovery' module is used to recover data from digital media (e.g memory sticks, flash drives and memory cards). There is a function specific to this module which can help recover digital data such as image, audio and video files. The 'CD/DVD Recovery' module can help you recover lost data from CDs, DVDs or Blu-ray discs that were formatted, damaged or erased. The module handles CD, DVD and Blu-ray data of many different types and formats. Each of the module's user interface is somewhat similar to the others to make it easy to operate. You select a local drive or device to start looking for information. Once the results are displayed, you can easily browse for files using the Explorer-based layout with familiar Explorer-type options. You can select or deselect any of the files from the current folder, toggle between the list and thumbnail viewing mode, or you can use a search function and configure an advanced search filter (by file name/extension, size, date). You can export the file list to a text document, view an icon and color legend, and preview the files (text, hex, image). MiniTool provides technical support option by email or phone. They also post a list of support topics online. Power Data Recovery is also available in a free version which does not allow you to "Load Previous Recovery Result". This feature allows you to choose to continue from the point where it was stopped during a previous recovery effort. The other main disadvantage to the free version is that you are limited to recovering 1 GB of data. The Personal Edition allows an unlimited amount of data recovery. MiniTool offers a bootable creation CD; however, it is an additional purchase. Review credit goes to our staff member bphlpt! Giveaway info: We are giving away 4 licenses for this great tool. All you have to do is to reply below and you will have the chance to win this software.
January 28, 201510 yr Hi, I would be very thankful if you would give a license to me. My mom , and me, use a lot of important stuff, and she needs this type of excellent recovery software. Thanks a lot. Edited January 28, 201510 yr by niTe_RiDeR_Pro
April 7, 20159 yr Easeus data recovery Recover deleted, formatted, inaccessible data. Amount of data you can recover: 2 GB
