c400 Posted January 26, 2015 Share Posted January 26, 2015 first of all thank you for your great work!!!i`ve found a small misstype http://i.imgur.com/gyDoerG.jpgRequest:i Would like you to ask to add in install.ini a parameter to disable showing the restart dialog with count dawn. A lot of people are frightening of this window ))))) Quote Link to comment Share on other sites More sharing options...
bphlpt Posted January 26, 2015 Share Posted January 26, 2015 Regarding the "mistype", (which you misspelled above, by the way ), of the word 'whilst', it's actually fine. From http://www.grammar-monster.com/easily_confused/while_whilst.htm: Most Americans find whilst quaint, old-fashioned, or literary. Most Brits, on the other hand, will swap happily between while and whilst, although some Brits also find whilst a little outdated.Some grammarians engaged in the while-whilst debate claim that, in the meaning during the time that or at the same time as, whilst should be used for a short period of time, and while should be used for a longer period of time.So since Lego is a Brit, and he is talking about a relatively short period of time, then his use of 'whilst' is perfectly correct, even if an American woulf most likely use 'while'.Cheers and Regards Quote Link to comment Share on other sites More sharing options...
c400 Posted January 26, 2015 Author Share Posted January 26, 2015 bphlpt :D :D sorry for a misspelling above. And for my stupidness)))but the thing about countdown... it is better to make it configurable in install.ini Quote Link to comment Share on other sites More sharing options...
bphlpt Posted January 26, 2015 Share Posted January 26, 2015 Out of curiosity, what is "frightening" about a "restart dialog with count dawn" window? And what would you suggest in its place? Surely you are not suggesting a restart without warning the user? Cheers and Regards Quote Link to comment Share on other sites More sharing options...
c400 Posted January 29, 2015 Author Share Posted January 29, 2015 Countdown is even more frightening for lammer users then error. I suggest to have a trigger in install.ini, which allows to make a restart without warning. Or with warning but without countdown and cancel button. I understand that it sounds like a joke, but i have a great experience of making mass products Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 28, 2015 Share Posted February 28, 2015 I've added a 'COUNTDOWN=TRUE' option in the install.ini file and changed some of the countdown dialogs a bit. Quote Link to comment Share on other sites More sharing options...
