Posted June 30, 200717 yr Easy & secure remote access from anywherePCHelpWare is a free alternative to the various paying remote assistance services that can be found on the netPCHelpWare is a powerfull remote support software that allows you to control (right from your own PC) a distant PC connected to the internet. It is the ideal solution to provide quick remote assistance and help your customers, collegues, friends and family members, even if they are on the other side of the worldPCHelpWare is customizable: you can create your own server package with your logo and -company- nameThe individual you want to remotely assist only has to download and execute your customized package. That's allNo router/modem/firewall configuration is needed to access a remote PC even when it's standing on a protected network behind a NATIf your PC is also behind Firewall/NAT routers, PCHelpware has the solution that makes everything simple anywayUsing the provided Repeater service, no router configuration is needed at allKey features * Security: Build-in communication encryption (TWF 256) and DH key exchange (using a 512 prime) * File transfer (using clipboard style Copy/Paste : ctr-alt-c, ctrl-alt-v) * Text Chat * Clipboard transfer (Text, RTF, HTML, pictures) * Scalable and easy to use Viewer. Various color modes to fit bandwidth at best * International keyboard support * Additional password if wantedViewer requirements (The Viewer is used to provide remote support and controls the remote PC once connected) * Windows 95, 98, ME, 2000, 2003, XP, Vista* * DirectX9.Oc Homepage & Download
