January 28, 201510 yr Does anyone know if there is a way of slipstreaming RAID drivers onto WHS 2011?The reason I ask is I am using a cfg.ini file to install as my SSD is only 140gb (to get around the min 160gb requirement) so I don't get to the "Load Drivers" screen.I have tried adding a drivers parameter in the cfg.ini file and get an error, so the only other thing I can think of is to slipstream them in (if possible) Does anyone know if the Win Toolkit will support WHS 2011? Thanks
