Posted January 30, 201510 yr Hello I put openoffice latest version 4.1.0 to install silent in the windows xp setup disk with the silent switch /S although it starts the installation it stops in a moment and rollback the installation,does anyone knows what is the problem? i`ve installed java before silent also.i tried with openoffice 3.3.0 and works but with openoffice 4.1.0 does not work i would appreciate any help
February 21, 201510 yr Probably the installation process has changed between versions. Below I've described my experience with creating a LibreOffice (similar) SVCPACK addon: Quote Oh man ... an unattended LibreOffice install ... not something I want to mess with ever again. The hardest part was realizing I needed to make an administrative MSI install to a folder, then figuring out all of the possible switches to get the configuration I wanted and placing them into an install.cmd file in the folder, then continuing with the regular steps per creating a standard nLite/RVMi addon. Here's my example of the file, your needs may differ: msiexec /qn /i LibreOffice_4.2.5_Win_x86.msi CREATEDESKTOPLINK=0 ALLUSERS=1 RebootYesNo=No ADDLOCAL=ALL ISCHECKFORPRODUCTUPDATES=0 QUICKSTART=0 SELECT_WORD=1 SELECT_EXCEL=1 SELECT_POWERPOINT=1 SELECT_VISIO=0 REGISTER_ALL_MSO_TYPES=1 IS1078=0 IS1025=0 IS1101=0 IS1610=0 IS1059=0 IS1026=0 IS2117=0 IS2121=0 IS1150=0 IS1603=0 IS5146=0 IS1027=0 IS32771=0 IS1029=0 IS1106=0 IS1030=0 IS1031=0 IS1604=0 IS2129=0 IS1032=0 IS2057=0 IS7177=0 IS1553=0 IS1034=0 IS1061=0 IS1069=0 IS1065=0 IS1035=0 IS1036=0 IS2108=0 IS1084=0 IS1110=0 IS1095=0 IS1037=0 IS1081=0 IS1050=0 IS1038=0 IS1057=0 IS1039=0 IS1040=0 IS1041=0 IS1079=0 IS1087=0 IS1107=0 IS1099=0 IS1042=0 IS1111=0 IS1120=0 IS1574=0 IS1134=0 IS1108=0 IS1063=0 IS1062=0 IS1605=0 IS1071=0 IS1100=0 IS1104=0 IS1112=0 IS1102=0 IS1109=0 IS1044=0 IS1121=0 IS1043=0 IS2068=0 IS1580=0 IS1132=0 IS1154=0 IS2162=0 IS1096=0 IS1094=0 IS1045=0 IS2070=0 IS1046=0 IS1048=0 IS1049=0 IS1569=0 IS1103=0 IS1606=0 IS1113=0 IS2074=0 IS2133=0 IS1051=0 IS1060=1 IS1052=0 IS3098=0 IS1579=0 IS1072=0 IS1053=0 IS1089=0 IS1097=0 IS1098=0 IS1064=0 IS1054=0 IS1074=0 IS1055=0 IS1073=0 IS1092=0 IS1152=0 IS1058=0 IS1091=0 IS1075=0 IS1066=0 IS1076=0 IS2052=0 IS1028=0 IS1077=0 IS1050=0 IS1033=1 REMOVE=gm_Langpack_r_af,gm_Langpack_r_am,gm_Langpack_r_ar,gm_Langpack_r_as,gm_Langpack_r_ast,gm_Langpack_r_be,gm_Langpack_r_bg,gm_Langpack_r_bn,gm_Langpack_r_bn_IN,gm_Langpack_r_bo,gm_Langpack_r_br,gm_Langpack_r_brx,gm_Langpack_r_bs,gm_Langpack_r_ca,gm_Langpack_r_ca_valencia,gm_Langpack_r_cs,gm_Langpack_r_cy,gm_Langpack_r_da,gm_Langpack_r_de,gm_Langpack_r_dgo,gm_Langpack_r_dz,gm_Langpack_r_el,gm_Langpack_r_en_GB,gm_Langpack_r_en_ZA,gm_Langpack_r_eo,gm_Langpack_r_es,gm_Langpack_r_et,gm_Langpack_r_eu,gm_Langpack_r_fi,gm_Langpack_r_fr,gm_Langpack_r_ga,gm_Langpack_r_gd,gm_Langpack_r_gl,gm_Langpack_r_gu,gm_Langpack_r_he,gm_Langpack_r_hi,gm_Langpack_r_hr,gm_Langpack_r_hu,gm_Langpack_r_id,gm_Langpack_r_is,gm_Langpack_r_it,gm_Langpack_r_ja,gm_Langpack_r_ka,gm_Langpack_r_kk,gm_Langpack_r_km,gm_Langpack_r_kmr_Latn,gm_Langpack_r_kn,gm_Langpack_r_ko,gm_Langpack_r_kok,gm_Langpack_r_ks,gm_Langpack_r_lb,gm_Langpack_r_lo,gm_Langpack_r_lt,gm_Langpack_r_lv,gm_Langpack_r_mai,gm_Langpack_r_mk,gm_Langpack_r_ml,gm_Langpack_r_mn,gm_Langpack_r_mni,gm_Langpack_r_mr,gm_Langpack_r_my,gm_Langpack_r_nb,gm_Langpack_r_ne,gm_Langpack_r_nl,gm_Langpack_r_nn,gm_Langpack_r_nr,gm_Langpack_r_nso,gm_Langpack_r_oc,gm_Langpack_r_om,gm_Langpack_r_or,gm_Langpack_r_pa_IN,gm_Langpack_r_pl,gm_Langpack_r_pt,gm_Langpack_r_pt_BR,gm_Langpack_r_ro,gm_Langpack_r_ru,gm_Langpack_r_rw,gm_Langpack_r_sa_IN,gm_Langpack_r_sat,gm_Langpack_r_sd,gm_Langpack_r_si,gm_Langpack_r_sid,gm_Langpack_r_sk,gm_Langpack_r_sq,gm_Langpack_r_sr,gm_Langpack_r_sr_Latn,gm_Langpack_r_ss,gm_Langpack_r_st,gm_Langpack_r_sv,gm_Langpack_r_sw_TZ,gm_Langpack_r_ta,gm_Langpack_r_te,gm_Langpack_r_tg,gm_Langpack_r_th,gm_Langpack_r_tn,gm_Langpack_r_tr,gm_Langpack_r_ts,gm_Langpack_r_tt,gm_Langpack_r_ug,gm_Langpack_r_uk,gm_Langpack_r_uz,gm_Langpack_r_ve,gm_Langpack_r_vi,gm_Langpack_r_xh,gm_Langpack_r_zh_CN,gm_Langpack_r_zh_TW,gm_Langpack_r_zu,gm_o_Activexcontrol,gm_o_Extensions_Script_Provider_For_BS,gm_o_Extensions_Script_Provider_For_JS,gm_o_Onlineupdate,gm_o_Quickstart,gm_r_ex_Dictionary_Af,gm_r_ex_Dictionary_An,gm_r_ex_Dictionary_Ar,gm_r_ex_Dictionary_Be,gm_r_ex_Dictionary_Bg,gm_r_ex_Dictionary_Bn,gm_r_ex_Dictionary_Br,gm_r_ex_Dictionary_Bs,gm_r_ex_Dictionary_Pt_Pt,gm_r_ex_Dictionary_Ca,gm_r_ex_Dictionary_Cs,gm_r_ex_Dictionary_Da,gm_r_ex_Dictionary_De,gm_r_ex_Dictionary_El,gm_r_ex_Dictionary_Es,gm_r_ex_Dictionary_Et,gm_r_ex_Dictionary_Fr,gm_r_ex_Dictionary_Gd,gm_r_ex_Dictionary_Gl,gm_r_ex_Dictionary_Gu,gm_r_ex_Dictionary_He,gm_r_ex_Dictionary_Hi,gm_r_ex_Dictionary_Hr,gm_r_ex_Dictionary_Hu,gm_r_ex_Dictionary_Is,gm_r_ex_Dictionary_It,gm_r_ex_Dictionary_Lo,gm_r_ex_Dictionary_Lt,gm_r_ex_Dictionary_Lv,gm_r_ex_Dictionary_Ne,gm_r_ex_Dictionary_Nl,gm_r_ex_Dictionary_No,gm_r_ex_Dictionary_Oc,gm_r_ex_Dictionary_Pl,gm_r_ex_Dictionary_Pt_Br,gm_r_ex_Dictionary_Ro,gm_r_ex_Dictionary_Ru,gm_r_ex_Dictionary_Si,gm_r_ex_Dictionary_Sk,gm_r_ex_Dictionary_Sr,gm_r_ex_Dictionary_Sv,gm_r_ex_Dictionary_Te,gm_r_ex_Dictionary_Th,gm_r_ex_Dictionary_Uk,gm_r_ex_Dictionary_Vi,gm_r_ex_Dictionary_Zu,gm_Reportbuilder,gm_o_Extensions_MEDIAWIKI,gm_o_Extensions_NLPSolver
