compstuff Posted January 31, 2015 Posted January 31, 2015 Hi All... Is their anyway to make NOT rebuilding the image the default setting? Quote
jgp Posted February 1, 2015 Posted February 1, 2015 You can uncheck rebuild image box before creating iso. Quote
compstuff Posted February 1, 2015 Author Posted February 1, 2015 Thanks for the response but I don't think you understand what I'm asking for because that doesn't change the DEFAULT setting that only changes it for that sessionYou can uncheck rebuild image box before creating iso. Quote
ianymaty Posted February 1, 2015 Posted February 1, 2015 (edited) Uncheck Rebuild Image in AIO Options tab. Sorry, if not that you want. I missread the original post. Edited February 1, 2015 by ianymaty Quote
compstuff Posted February 2, 2015 Author Posted February 2, 2015 I was hoping that was the answer but it doesn't really apply. When I go straight to the ISO Maker it just seems to always default to Rebuild and if I am hasty and forget to uncheck it just adds so much time in my testing... especially when I am testing maybe 20 builds or so. Thanks Anyway Uncheck Rebuild Image in AIO Options tab.Sorry, if not that you want. I missread the original post. Quote
Legolash2o Posted February 6, 2015 Posted February 6, 2015 No there isn't a way, it's not much effort to uncheck a box as your mouse is heading towars the create iso button Quote
compstuff Posted February 7, 2015 Author Posted February 7, 2015 (edited) Hope University is going well for you! Edited February 7, 2015 by compstuff Quote
bphlpt Posted February 7, 2015 Posted February 7, 2015 I guess another option would be if a pop up could occur when you press the Create ISO button that would say something like: "The ISO will be Created and the Image will be Rebuilt starting in 3 seconds, or press here to abort..." But others think countdowns are scary, so that might not work either. It doesn't seem too big a request to allow the default behavior to be modified in the settings, or even in an INI file, but I could be wrong. Cheers and Regards Quote
Legolash2o Posted March 1, 2015 Posted March 1, 2015 I've just made it so it will remember what you chose a previous time Quote
compstuff Posted March 1, 2015 Author Posted March 1, 2015 WOW Thanks very much :prop:I've just made it so it will remember what you chose a previous time Quote
