Nameless Mofo Posted February 13, 2015 Posted February 13, 2015 Legolas, first I love this awesome tool, thank you for your fine work. But two problems I have noticed however trying to integrate IE11, one quite annoying and one minor. Would appreciate if you could look into them. OS source = Windows 7 Ultimate x86/x64 SP1 (both)WTK version = 1.5.3.10 Trying to integrate all post-SP1 fixes at once, including IE11 (main .cab) + IE11 language packs + IE11 updates. BUG #1: when I try to integrate the IE11 .cab + IE11 lang packs (German, Russian) in one go, WTK complains, saying "multiple versions of Internet Explorer have been selected" or something similar. The main IE11.cab I got via Windows Update Downloader, the language packs I got direct from MS. When I load them into WTK AIO, all 3 get tagged as "Internet Explorer 11". Is there a way to have WTK integrate all 3 packages correctly? BUG #2: more of an enhancement request. Right now every time I want to do an integration (which now includes IE11 every time) I have to manually move the IE11-specific updates to the "Internet Explorer" section of the AIO Updates tab. Can WTK be made to remember that these updates need to go under the IE tab? Thanks! Quote
Thiersee Posted February 13, 2015 Posted February 13, 2015 Hi, BUG #1: no idea, sorry. BUG #2: WTK detects already IE11-Updates, if they are named IE11-KB1234567.msu and moves them to the IE-11 section. Quote
Nameless Mofo Posted February 21, 2015 Author Posted February 21, 2015 Bueller? I'd really like to know if there's a way Legolas might look at bug #1, or at least suggest a workaround. Bug #2 makes sense because I do use a different naming convention for my update library. Quote
Legolash2o Posted February 28, 2015 Posted February 28, 2015 I downloaded IE11 and the lang packs from the same sources and the languages packs get recognized as 'IE Langpack', however I've added an option to 'continue anyway?'. As mentioned above anything with IE11- in the file name will automatically get recognized and moved to the correct section. I won't add the enhancement request in v1.x but most likely in v2.x Quote
Nameless Mofo Posted March 2, 2015 Author Posted March 2, 2015 Hi Legolas, thanks for the update. Putting off the enhancement I mentioned is fine. I do have one question: where do you get your IE11 lang packs? I got them direct from MS by looking up the IE11 KB article and selecting languages from there. If there's a better source with file versions that WTK handles correctly I'd love to hear about it. Quote
abbodi1406 Posted March 2, 2015 Posted March 2, 2015 You mean this? http://www.microsoft.com/en-us/download/details.aspx?id=40904 Quote
Legolash2o Posted March 2, 2015 Posted March 2, 2015 I put off the suggestion because I don't really spend time with v1.x anymore and focus on v2.x Quote
Nameless Mofo Posted March 5, 2015 Author Posted March 5, 2015 You mean this? http://www.microsoft.com/en-us/download/details.aspx?id=40904 Yes preceisely, that's where I got the ie11 lang packs from, but when I try to integrate them with 1.5.3.10 (.12 does the same) it refuses because WTK tags them as "Internet Explorer 11" along with the main ie11 cab file. Quote
