Which updates to avoid when merging
Hi All,
I am new to this forum and to Wintoolkit.
Basically what I am trying to do is to take a clean Windows 7 sp1 X64 image and integrate as much updates as possible.
I did a run without all the optional updates. This iso would install just fine but I would like to create a image where I could have
optional updates as well, like IE11 etc. Unfortunately when trying to do this I get errors while installing the image in VMware player.
I've been trying to search the forums and found some posts about certain updates conflicting and they should be left out.
Is there a list of known updates which can't be integrated even tough they are still downloaded by wintoolkit?
sorry if I'm asking stupid question.
Thanks in advance,
roumen
Posted (edited)
All updates in Extra (not needed for most users)
Additional\_NotAllowedOffline (as there title says)
Additional\WMF4.0 (require .NET 4.5 or higher to be present in image)
Edited by abbodi1406
Okay, thanks for the update. I've removed them from my updates folder.
There is just one thing that I can't seem to get fixed and that's how I should integrate IE11.
These are the updates it downloaded for ie11 but when I create the iso and install my
image in a VM ie8 is still the default browser.... What would be the cause of this?
Here's an image:
http://imgur.com/Q8zQnyD
Here's an image:
You can take a look on this tool genarly it's add all update to dvd as beater choise you chould pick
http://forums.mydigitallife.info/threads/45005-Simplix-Pack-to-update-Live-Win7-System-Integrate-hotfixes-into-Win7-distribution
