Posted February 25, 201510 yr I've decided to go through the free / pro editions. THE PRICES AND WHAT COMES WITH EACH EDITION CAN BE NEGOTIATED IN THIS TOPIC FREEAll-In-One IntegratorUpdates, Drivers, Wallpapers. Failed updates will still go to Silent Installers list ISO MakerUSB Prep ToolHOME [£$€ 5]No advertisements on links.All-In-One IntegratorWallpapers, gadgets,Tweaks, Theme packs, Silent InstallersConvertersAIO Disk CreatorAddon MakerBasic Windows 8.1 exclusive ISOsPRO [£$€ 15]Everything elseFull All-In-One Integrator (all tabs available)ESD Support (well converter anyway)Live OS supportWIM Registry EditorUnattended CreatorAll exclusive ISOsI best get back to programming Can you think of anything else which should be free or in home edition?
February 25, 201510 yr I think Silent Installers should be in free version, what do you think ?Also, what's the difference between All-In-One Integrator & Full All-In-One Integrator ?
February 25, 201510 yr Author If people agree that silent installers should be free, then I'll make it free. I just meant that you'll have access to all of the tabs
February 25, 201510 yr I think that "All you can add without the program to moddify something" should be free including prepared silent installers. Also the KB's that need to go to silent install should be also free. All other things where you need the program to do something to create or extract / convert or something should go for Home or Pro.
February 27, 201510 yr I agree with this this is fare enough to be acceptable for any one ,oh BTW the license should be by the hardware id due the carcking issue :g:
February 27, 201510 yr I Would be fine with hardware id's, but for me i often change stuff like hdd's so.. depens for me what hardware id is gone be used.Though how would a hardware id check stop a crack ? simply nop the check and its done. Back on topic, i am fine with a pro version, 15 euro ? sure, i need the esd support so.Not really need but want .
February 28, 201510 yr Author For part of my project I will be experimenting with different protection methods so hardware IDs would be tested too. ESD support would only be a converter as there is no way in getting past mounting an actual ESD without converting it first.
March 1, 201510 yr For part of my project I will be experimenting with different protection methods so hardware IDs would be tested too. ESD support would only be a converter as there is no way in getting past mounting an actual ESD without converting it first. lego can you add future to the converter like convert esd windows dvd into to an normal install.wim or convert the esd dvd to an iso to install .esd format too that becuse there msdn iso came in esd format by default .
March 1, 201510 yr Author The ESD converter will let you convert esd to wim and wim to esd The ISO Maker will function work with either.
March 1, 201510 yr The ESD converter will let you convert esd to wim and wim to esd The ISO Maker will function work with either. I had a question why wintoolkit can use it on dism from windows 8.1 AIK the total size is 7+ mb withe compersing its less than 1.3 mb .is this will help in speeding the WTK work by any way or maybe the defualt dism it's just fine :g:
March 1, 201510 yr Author WTK can't use it at the moment. For someone reason I can't use WIMGAPI to get the amount of images inside the install.esd. DISM.exe can get the amount of images but for the life of me I can't find a way to get it via a wimgapi/dism.dll or any other dll call. I've posted on the MSDN forum but not response yet. I can't even start ESD support until someone answers that :'(
March 3, 201510 yr Maybe you could ask wimlib author, or use it as alternative I agree with your seggustion abbodi , the wimlib is much faster than the dism , but is that will make any limitaion to WTK , an other thing this mean re coding the hole WTK to be suiteable with wimlib
March 3, 201510 yr Hi all, Great project!Can not wait for PRO version.Legolash2o, could you please tell me when approximately are you planning to relase PRO version ?
March 3, 201510 yr Author You can download the latest build from my signature. To further answer your question, I have to have the same features available as v1.x by May, but at the rate I've been going at the past 3 days it will be sooner than that @EveryoneAre the prices OK?
March 3, 201510 yr @EveryoneAre the prices OK? More than OK! I would suggest you to set the prices separately in GBP (your currency), USD and €; I would say: 5 GBP (or 7 € or 7,50 $, depending on change) and15 GBP (or 18 € or 20 $, depending on change) Edited March 3, 201510 yr by Thiersee
March 4, 201510 yr I agree with your seggustion abbodi , the wimlib is much faster than the dism , but is that will make any limitaion to WTK , an other thing this mean re coding the hole WTK to be suiteable with wimlibI ment to ask him about wimgapi issue, not to use wimlib instead -- prices looks OK to me.
March 4, 201510 yr The Website ... good. The prices are ok. :thumbsup: Term for grand opening? :fun: :beerchug:
March 4, 201510 yr Author I'm aiming for april or even before. ISO Maker is almost done. Once that is done, I can start the WIM related stuff.
March 7, 201510 yr Website looks nice - but this killed me: <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> Why HTML4 ?
