  • Replies 59
  • Views 36.5k
  • Legolash2o
    Legolash2o
    Sure, that would be great   If you're wondering why there's not many posts, it because I'm coming to the end of the year and have to finish the WTK report and other coursework. 2 more weeks and it's
  • Legolash2o
    Legolash2o
    The ESD converter will let you convert esd to wim and wim to esd The ISO Maker will function work with either.
  • Legolash2o
    Legolash2o
    You can download the latest build from my signature. To further answer your question, I have to have the same features available as v1.x by May, but at the rate I've been going at the past 3 days it w
@Everyone
Are the prices OK? :)
More than OK!
I would suggest you to set the prices separately in GBP (your currency), USD and €; I would say:
5 GBP (or 7 € or 7,50 $, depending on change) and
15 GBP (or 18 € or 20 $, depending on change)
So are the prices like this or are they all one price regardless of currency type/country?
  • 5 weeks later...
I have not been around for a while and have a question about this new pricing scheme.  (Forgive me if someone has asked it already elsewhere.)
If a person made a donation while WTK v1.x was being developed, will that carry over to v2.x?
I just need to determine if I need to save up for a donation on this newer version. (Currently running on limited funds.)
Depends on the size of the donation. Also people who have been around for a while and helped out. :)
That is cool. I will probably make another donation anyway.  I am doing better than I used to be (not great, but better).
Edit:  I just realized, how does one make a donation now, or is there an "automated" way or what?
Edited by crashfly
  • 4 months later...
Hi Legolash2o,
Any update on newer 2.x versions? 2.0.5860.25216 keeps on crashing at startup. I'm on Win7 x64. Is it supposed to run only under Win10?
Also, when will it be possible to buy an official license and get the official builds rather than just test builds?
Thanks
no issue for me with proposed list, I will also donate again soon.
My suggestion is tho once people start paying for this as a product then documentation is needed for all the features.
  • 2 years later...
