Posted (edited)
I have a problem trying to integrate the next 2 updates. I use the original iso of windows 8.1 update 3
Title: 2 error(s) have occurredErrType: ErrorDescription: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception: An error occurred whilst integrating an update!Exception:Microsoft Windows [Versi�n 6.3.9600](c) 2013 Microsoft Corporation. Todos los derechos reservados.D:\Windows Desatendido\- Programas\- Windows Toolkit>chcp 65001D:\Windows Desatendido\- Programas\- Windows Toolkit>Set SEE_MASK_NOZONECHECKS=1D:\Windows Desatendido\- Programas\- Windows Toolkit>"C:\Windows\System32\Dism.exe"  /Image:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- WIM_7FDCBE731E475A7941DFFF7FE208C825" /Add-Package /PackagePath:"D:\Windows Desatendido\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x86\Security\Windows8.1-KB3038031-x86.msu" /ScratchDir:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- Updates\WinToolkit_Temp\ScratchDir_6CCC7F15AC3D9742D2A3A75440A30F12" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.17031Image Version: 6.3.9600.17031Processing 1 of 1 - D:\Windows Desatendido\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x86\Security\Windows8.1-KB3038031-x86.msu: An error occurred while expanding the .msu package into the temporary folder, D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- Updates\WinToolkit_Temp\ScratchDir_6CCC7F15AC3D9742D2A3A75440A30F12\AD6617C3-65FB-4C16-87D0-7F7100ECBA47.  Error: 0x8007065eError: 1630DISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Windows Desatendido\- Programas\- Windows Toolkit>exit----------------------------------An error occurred whilst integrating an update!Exception:Microsoft Windows [Versi�n 6.3.9600](c) 2013 Microsoft Corporation. Todos los derechos reservados.D:\Windows Desatendido\- Programas\- Windows Toolkit>chcp 65001D:\Windows Desatendido\- Programas\- Windows Toolkit>Set SEE_MASK_NOZONECHECKS=1D:\Windows Desatendido\- Programas\- Windows Toolkit>"C:\Windows\System32\Dism.exe"  /Image:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- WIM_7FDCBE731E475A7941DFFF7FE208C825" /Add-Package /PackagePath:"D:\Windows Desatendido\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x86\Hotfix\Windows8.1-KB3022776-v3-x86.msu" /ScratchDir:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- Updates\WinToolkit_Temp\ScratchDir_DABDE35621FF1BEC1B42D86EB6E5C882" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.17031Image Version: 6.3.9600.17031Processing 1 of 1 - D:\Windows Desatendido\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x86\Hotfix\Windows8.1-KB3022776-v3-x86.msu: An error occurred while expanding the .msu package into the temporary folder, D:\Windows Desatendido\- Programas\- Windows Toolkit\- Temp\- Updates\WinToolkit_Temp\ScratchDir_DABDE35621FF1BEC1B42D86EB6E5C882\EFD80892-D891-4FE7-BAE4-1B0B721596A4.  Error: 0x8007065eError: 1630DISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Windows Desatendido\- Programas\- Windows Toolkit>exit----------------------------------
Edited by avechuche
Posted (edited)
Now I have problems with the x64 version and also there is an update that matches the problem that I have the x86 version .
Download again 2 updates and still not working. Do not think it's a problem of mine , because it's much chance that the same update that fails both versions of windows . I'm using the version Update 3.
Title: 2 error(s) have occurredErrType: ErrorDescription: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception: An error occurred whilst integrating an update!Exception:Microsoft Windows [Versi�n 6.3.9600](c) 2013 Microsoft Corporation. Todos los derechos reservados.D:\Windows Desatendido\- Programas\- Windows Toolkit>chcp 65001D:\Windows Desatendido\- Programas\- Windows Toolkit>Set SEE_MASK_NOZONECHECKS=1D:\Windows Desatendido\- Programas\- Windows Toolkit>"C:\Windows\System32\Dism.exe"  /Image:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- WinToolkit_WIM_C9377F6B68550CAA68370A85B6C36972" /Add-Package /PackagePath:"D:\Windows Desatendido\- Programas\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x64\Hotfix\Windows8.1-KB3022776-v3-x64.msu" /ScratchDir:"D:\Windows Desatendido\- Programas\- Windows Toolkit\WinToolkit_Temp\ScratchDir_CBC6034DF8ABFBB3F69253DA17EB35C8" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.17031Image Version: 6.3.9600.17031Processing 1 of 1 - D:\Windows Desatendido\- Programas\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x64\Hotfix\Windows8.1-KB3022776-v3-x64.msu: An error occurred while expanding the .msu package into the temporary folder, D:\Windows Desatendido\- Programas\- Windows Toolkit\WinToolkit_Temp\ScratchDir_CBC6034DF8ABFBB3F69253DA17EB35C8\1934F63C-C444-44D4-A3B4-517429CE86D0.  Error: 0x8007065eError: 1630DISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Windows Desatendido\- Programas\- Windows Toolkit>exit----------------------------------An error occurred whilst integrating an update!Exception:Microsoft Windows [Versi�n 6.3.9600](c) 2013 Microsoft Corporation. Todos los derechos reservados.D:\Windows Desatendido\- Programas\- Windows Toolkit>chcp 65001D:\Windows Desatendido\- Programas\- Windows Toolkit>Set SEE_MASK_NOZONECHECKS=1D:\Windows Desatendido\- Programas\- Windows Toolkit>"C:\Windows\System32\Dism.exe"  /Image:"D:\Windows Desatendido\- Programas\- Windows Toolkit\- WinToolkit_WIM_C9377F6B68550CAA68370A85B6C36972" /Add-Package /PackagePath:"D:\Windows Desatendido\- Programas\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x64\Hotfix\Windows8.1-KB3024680-v2-x64.msu" /ScratchDir:"D:\Windows Desatendido\- Programas\- Windows Toolkit\WinToolkit_Temp\ScratchDir_197A108419D377AC7C182142FD131AA6" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.17031Image Version: 6.3.9600.17031Processing 1 of 1 - D:\Windows Desatendido\- Programas\- Windows Hotfix Downloader\Updates\Windows8.1-Update3-x64\Hotfix\Windows8.1-KB3024680-v2-x64.msu: An error occurred while expanding the .msu package into the temporary folder, D:\Windows Desatendido\- Programas\- Windows Toolkit\WinToolkit_Temp\ScratchDir_197A108419D377AC7C182142FD131AA6\62311135-011E-40F0-8192-2D73482942E7.  Error: 0x8007065eError: 1630DISM failed. No operation was performed. For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logD:\Windows Desatendido\- Programas\- Windows Toolkit>exit----------------------------------
2) And that means yellow/orange check ?
Edited by avechuche
