shahed Posted July 2, 2007 Posted July 2, 2007 Hi Can someone please make the addon NET3 to slipstream into my xpcd please. or if it is available then please give me a link to download for it.thank you Quote
shahed Posted July 2, 2007 Author Posted July 2, 2007 Swichless installer can be found here.the link provided is not working Quote
shahed Posted July 5, 2007 Author Posted July 5, 2007 hithanks for the working link, but one more question how do i slipstream into to my xp cd. which program do i use? Quote
Gorki Posted July 5, 2007 Posted July 5, 2007 hithanks for the working link, but one more question how do i slipstream into to my xp cd. which program do i use?If u download Ryan AIO beta2 pack use this method:Here's how I made my own switchless installer addon.1. Create a text file in notepad, name it "entries_dotnetaio.ini".2. Open the entries ini file in notepad and paste the following.Code: [general] builddate=04/07/2007 description=Ryan's DOTNET AIO language=English version=beta2 website=http://www.ryanvm.net/forum/ [EditFile] I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram [AddProgram] dotnetaio.exe3. Save and close the ini file.4. Create a folder named "svcpack" and copy the dotnetaio.exe file into it.5. Use 7zip to 7z cpmpress both the ini file and the svcpack folder together and name it "ProgramAddons_DOTNETAIO.7z" Quote
shahed Posted July 6, 2007 Author Posted July 6, 2007 hithanx for the code. did try it, and slipstreamed it with RVM integrater, and installed with VMware Workstation but when i go to windows update, it shows that no NET framework is not installed, and gives me the options to install it. (Which means the DOTNET AIO has some code or switch problems) Anyway,PLEASE just make me the addon NET framework 3 only. NOT the the DOTNET AIO. Just NET 3, as i have NET 1, and NET 2, addons already.thank you really appreciate your efforts Quote
ricktendo Posted July 6, 2007 Posted July 6, 2007 Thats your problem... You integrate it with the 1 and 2. This causes an error, just use the AIO.Its the only way to integrate all 3 together Quote
shahed Posted July 6, 2007 Author Posted July 6, 2007 NO i did not integrate 1 and 2, only the AIO Quote
Helmi Posted July 7, 2007 Posted July 7, 2007 PLEASE just make me the addon NET framework 3 only. NOT the the DOTNET AIO. Just NET 3, as i have NET 1, and NET 2, addons already.NO i did not integrate 1 and 2, only the AIOSo, what now?Did you also integrate those two other addons along with the AiO or not?If so, then Rick is telling you to drop these as they are now superficial since you got the AiO pack.If not, then I don't know what's wrong here... Quote
shahed Posted July 7, 2007 Author Posted July 7, 2007 ITS WORKIN FINE NW THANK YOU FOR YOUR TIME, AND EFFORTS. MY MISTAKE WAS NET 1 AND 2 WAS ALREADY INTEGRATED FROM BEFORE, AND I WAS INTEGRATING AIO ON TOP. THANK YOU Quote
Helmi Posted July 8, 2007 Posted July 8, 2007 You're welcome! Just please don'T shout at us anymore, will ya? Quote
shahed Posted July 8, 2007 Author Posted July 8, 2007 am very impatience person u know, sori 4 shouting it was great help from you guys thanx Quote
