Posted March 28, 201510 yr Host OS: Windows 7 Ultimate x64Image OS: Windows 7 x64Windows ADK for 8.1 installed: Yes (I used this link http://www.microsoft.com/en-us/download/confirmation.aspx?id=39982) In WinToolkit v1.5.3.12, when I add the kb2603229, kb3035126, kb3035132 they show up and the program says they are integrated. But when I test the image, Windows updates says they are not integrated. They are integrated when I use the dism command in cmd.
March 31, 201510 yr kb2603229 is one of a handful of no-integrate updates for x64. The other two I don't know about, try downloading direct from MS update catalog site (catalog.update.microsoft.com) as the ones you have may be corrupted.
April 6, 20159 yr Author They are downloaded from catalog.update.microsoft.com, I use this site for downloading the .msu updates. "kb2603229 is one of a handful of no-integrate updates for x64." They are integrated when I use the dism command in cmd."corrupted" nope, used a CRC checker.
April 6, 20159 yr ......"kb2603229 is one of a handful of no-integrate updates for x64." They are integrated when I use the dism command in cmd."corrupted" nope, used a CRC checker.KB2603229 is NOT integratable offline! Note for OEMs and system buildersDo not slipstream this update into preconfigured operating system images. You must run this update only after the operating system is installed and the Out-of-Box Experience (OOBE) is finished.from: http://support.microsoft.com/en-us/kb/2603229
April 7, 20159 yr Author @Thiersee I did not know that, thanks.I will insert it in the SetupComplete.cmd Why can't microsoft put a allowedOffline="false" like in the kb2533552.
June 13, 20159 yr Strange, I had never problems withKB3035126 & KB3035132 tried again just now version 1.5.3.12 and the two KBs have been integrated and installed (under updates, NOT Silent-Installers) and NOT requested by WU. Integrated OS Windows 7 Home Premium x86Host OS Windows 7 Professional x64. Thiersee
June 14, 20159 yr KB3035126 & KB3035132 integrated and installed and not requested by windows update.Not need to move silent installer section.
June 16, 20159 yr Sorry, no SOLVED. KB3035126 + KB3035132 works great without Silent Installers. Here are two different outstanding!!! Please try yourself, it works (try last 1.5.3.20 to check it!!!) I myself have put the together: www.comic-site.de/all-right-kb3035126.rar Edited June 16, 20159 yr by Cartman586
June 19, 20159 yr Hello Liam,again on the subject KB3035126, KB3035132.Microsoft has here two different versions in circulation.Here is my link to the most recent:www.comic-site.de/all-right-kb3035126.rarI have tested this on Windows 8.1 x86 + x64 and Windows 7 x86 + x64.It works flawlessly.Please make the Silent Installer in version 1.5.3.21 Undo again.Thank you
June 21, 20159 yr Hi Liam, with Version 1.5.3.21 Windows Update Displays KB3035126 + KB3035132 (see Screen)Options > I disable "Move know Problem Updates to Silent Installers" !!! Microsoft has from KB3035126 + KB3035132 (Two different KB's in circulation)
June 21, 20159 yr Hi Liam, here the same test with Version 1.5.3.20 Windows Update dosn't Display KB3035126 + KB3035132 (see Screen)Here, Wintoolkit do this KB's automaticly integrate. Please Help Edited June 21, 20159 yr by Cartman586
June 21, 20159 yr I shall remove these from the automatic moving list and release when I get my new HDD dock. EDIT: In fact I will develop something which should help in future releases
