How do I create an ISO image using WimSplitter?
I create ISO images with WimSplitter but do not work, do not work, I have requested help in this regard but the author has not given any response.
Does anyone know how to use WimSplitter?
I'm not sure, but it might make a difference as to which OS and architecture you are trying to build, whether or not you are trying to use UEFI, whether you need to split the WIM because you are also trying to add a lot of addons, and other factors.  You'll have to wait until someone who knows more than I to respond, but in the meantime, the more info you can provide might help clarify the situation.
