Thiersee Posted March 30, 2015 Posted March 30, 2015 (edited) Hi, just a simply question (but may be the explanation is present and I do not see it...): DISM 8.1 is set in WTK-options, but if I look into C:\Windows\Logs\Dism\DISM.log I see only the original DISM from Windows (C:\Windows\System32\DISM.exe)! Settings.txt:fAddons=D:\Users\Capo\DownloadsfDrivers=E:\Driver_Mainboard\Realtek_Win7_7092_02252015\WIN7\64fSilents=E:\ServicePacks-Install\Win_7\Windows_7_Toolkit\ThierseefUpdates=E:\ServicePacks-Install\Win_7\WindowsUpdateDownloader\Win 7 Post SP1 GDR Updates x64 MULTI\UpdatessWinToolkitTemp=C:\WinToolkit_TempsMountTemp=C:\WinToolkit_MountsAddRunOnce=TruesAICommands=TruesAVScan=TruesAIOSave=TruesUpdFilter=TruesAIOTIME=09m:03ssPreventSleep=TruesCheckForUpdates=TruesDLogging=TruesDISMUpdate=TruesFreeRAM=TruesLastDir=C:\MountsLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wimsPLastWIM=E:\Win7_Prof_x64_DE_SP1_X17-59885\sources\install.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886\sources\install.wim|E:\Win7_Prof_x64_IT_SP1_X17-59215\sources\install.wim|E:\Win7_Prof_x64_IT_SP1_X17-59215\sources\install - Kopie.wim|E:\Win7_Prof_x86_DE_SP1_X17-59886\sources\install - Kopie (4).wim|sDeleteMount=TruesmCheck=FalsesAIOPM=TruesQuickMerge=TruesFormSize=|frmLPConvert:750*400|frmUnattendedCreator:700*500|frmUpdCatalog:896*431|frmUSBPrep:750*300|frmEXEtoMSP:750*627|frmAIODiskCreator:760*464|frmMSUtoCAB:750*400|frmWIMManager:790*350|frmAllInOne:1546*1040smVerify=FalsesSolDownload=E:\Windows_7_Toolkit-Ausfuehren\Updates\sTransparency=100sTransparencyAll=FalsesWinToolkitDISM=HighsWinToolkitExt=NormalsWinToolkitPRI=NormalsUploadLogs=TruesLastISO_Folder=E:\Win7_Prof_x86_DE_SP1_X17-59886sLastISO_ISO=E:\ISO's\WinToolkit\W7-HP_DE_x86_LAP_153B12_2703.isosMountLog=TruesShowWelcome=FalsesRegistryLog=FalsesDismLoc=C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe| ^ | |from dism.log:2015-03-29 12:23:42, Info DISM DISM.EXE:2015-03-29 12:23:42, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->2015-03-29 12:23:42, Info DISM DISM.EXE:2015-03-29 12:23:42, Info DISM DISM.EXE: Host machine information: OS Version=6.1.7601, Running architecture=amd64, Number of processors=42015-03-29 12:23:42, Info DISM DISM.EXE: Executing command line: "C:\Windows\System32\Dism.exe" The only thing "not normal" (for me!), that I see is the vertical bar after dism.exe. Thanks for your answers. Thiersee Edited March 30, 2015 by Thiersee Quote
Thiersee Posted April 1, 2015 Author Posted April 1, 2015 Hi Lego, working on Windows 7 x64: version 1.5.3.Test13 still uses the OS-DISM (C:\windows\system32\dism.exe), no matter which DISM-version is in the settings.txt ("custom") version 1.5.3.Test19 experimental uses the "custom" DISM (in my case C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe) No idea if the same happens working on Win 8.1. Thiersee Quote
Legolash2o Posted April 2, 2015 Posted April 2, 2015 As you mentioned, I've already fixed that in the experimental build Quote
Thiersee Posted April 2, 2015 Author Posted April 2, 2015 As you mentioned, I've already fixed that in the experimental build Yes, but the issue with the add-on is still present... Quote
