Posted April 6, 20159 yr [Repack] Avast! Free Antivirus 2016 v v12.3.3154 [Multilang]... ;-) -To Silent install use /silent or /verysilent... -No install Toolbars or other junks... Thanks to @darkblood by his installer & silent switches... http://www.wincert.net/forum/topic/12693-repack-avast-free-antivirus-v902021515-repack-with-silent-install-switch/#entry115021 Regards... ;-) Download: Quote https://mega.co.nz/#!K5pigCYZ!AAAAAAAAAABVgid3dbZkVQAAAAAAAAAAVYInd3W2ZFU Edited January 12, 20178 yr by alfreire
July 16, 20159 yr Is it possible for you to explain to how did you do this? I've been using unattended install for a long time and never managed to do such things as repacking this Avast install full of crapware. BTW, I'm asking on how you managed to repack this cuz I wanna do a portuguese brazilian repack too. Regards! P.S.: I've been searching something like a "HOWTO" or some kind of guideline, but all I got is too much spread information. Hope you are in a mood of sharing the info. Edited July 17, 20159 yr by jeiderdamm
January 11, 20178 yr On 07/04/2015 at 0:42 AM, alfreire said: [Repack] Avast! Free Antivirus 2016 v11.2.2261 [Multilang]... ;-) Download: Hi. Your download link is dead..
January 12, 20178 yr Author 12 hours ago, Valittaja said: Hi. Your download link is dead.. Updated to v12.3.3154... Cheers... ;-)
March 9, 20177 yr On 1/12/2017 at 3:30 PM, alfreire said: Updated to v12.3.3154... Cheers... ;-) please give me silent switches for avast pro anti-virus, avast internet security and avast premier anti-virus please ?
March 9, 20177 yr Author 40 minutes ago, Nguyen Anh Tuan said: please give me silent switches for avast pro anti-virus, avast internet security and avast premier anti-virus please ? Hi... to find switches you must do this: Run offline installer in Virtual Machine and wait to the program is iddle (yo can see Google offfer window) Go to %temp% folder and copy _av_iup.tm~a*** folder to other location Finalize installation and then open C:\ProgramData\AVAST Software\Persistent Data\Avast\Logs\Setup.log file with Notepad Search for instup.exe" /edition (in line 9 +-) Command: '"C:\Users\Administrador\AppData\Local\Temp\_av_iup.tm~a00668\instup.exe" /edition:1 /ga_clientid:124e581d-f162-47a7-a518-f372afb62e8d /guid:21e128e4-bea6-4bc6-b618-a46c75ccefec /prod:ais /sfx /sfxstorage:C:\Users\Administrador\AppData\Local\Temp\_av_iup.tm~a00668' You can edit comand like this: Quote instup.exe /sfx /sfxstorage:C\AvastFiles /edition:1 /prod:ais /silent You must run command from the folder that contain Avast files copied from temp folder Change C:\AvastFiles for your own folder edition:1 is Free version, you can discover the other version numbers by runing same steps installing other Avast versions Cheers... ;-)
