Posted July 3, 200717 yr NoRCoTI (No Right-Click on Tray Icon) disables to right-click ona specific tray icon.Usage:------Place a 16x16 icon of the program in the current working directory.Press Ctrl+Alt+Shift+T if you want to exit NoRCoTI.Working:--------NoRCoTI does not have any user interface. If it cannot find the icon in its path, then it'll present a file open dialog box and will copy the icon to the working directory.To check if NoRCoTI is working properly, move your mouse over the tray icon of the program you specified. The scroll-lock light on the keyboard should turn on. It will turn off as soon as the mouse is moved away from the tray icon.Tips for extracting the 16x16 icon:-----------------------------------Open the main EXE file of the program you want to protect using an icon editing program like IconWorkshop or Icon Sushi (freeware).If a 16x16 icon isn't present in the EXE, then you'll need to resize any larger icon to 16x16 and save it.Only extract that 16x16 icon which has the highest colors (ie choose WinXP or 32 bit over 24/16/8/4 bits)Credits:--------Thanks to nodiague for the original idea for making this program!NORCOTI.zip
July 3, 200717 yr You may want to remove that...Links: Zip and Exe.Several results of trojans/worms and other suspicious results.
July 3, 200717 yr Author I won't remove it until someone proves that this will make damage to your computer by installing trojan.
July 4, 200717 yr I wouldn't want to risk it. If they get infected by getting the file from here, they may very well blame you and the site. But it's your site and your risk.
July 4, 200717 yr The file doesn't contain any virus. It was compressed with UPX which is why there are a few false alerts. (I wouldn't call three = "several"). Infact, if you upload the UPX binary itself, you'll see that there's a similar pattern of results : http://www.virustotal.com/vt/en/resultadof...7e0d58a0b64f652As you can see, the top AVs such as Kaspersky, NOD32 and BitDefender haven't detected it. Even Avast and AVG shows a negative.Please don't take the results of VirusTotal seriously, unless atleast 50% of the scanners show a positive.Finally, the best way to determine if a file is harmful or not is not by scanning with malware scanners, but by executing it in a sandboxed environment and monitoring it for what changes it makes to the system. You may also use a packet sniffer like WireShark to check what data a file is sending over the network (if any).Simply scanning a file with an AntiVirus doesn't prove the harmfulness or the harmlessness of a file.Oh, and incase your office network uses eSafe / Panda or WebWasher and you don't want their AVs to go bonkers, you can download the non-UPX compressed file from here:NORCOTI_v1.1_noUPX.zip
