Bro help me !
I cant install windows7 in my computer.
I use X17-59465(Windows 7 Ultimate x64).ISO
I copied the installer by Rufus
On GPT partition selection UEFI
then i set bios secure boot : disable
then i press F12 boot by USB
but Window freezes at 4 flag
Bro help me !! plss
I dont want change setting | UEFI => CSM(lagecy boot) + GPT =>MBR
Bro help me !
I try unzip windows 8.1.iso in folder Windows 7
then replace file install.wim (windows 7.iso) into Windows 7/sources
I copied it into USB
boot it boot success same window 8.1
Flag blue + circle
i format HDD to install but i restart first
  • 4 weeks later...
SecureBoot and all the CSM functionality doesn't have any effect on Win 7.
Also UEFI-Boot doesn't work on any other than FAT32.
UEFI doesn't do anything to your Boot-functionality
(other than forcing it into FAT32) and it does not
magically turn your USB into a magic carpet.
Therefore - rethink your approach and opt for compatibility
