Hello,
please can anyone repak K-lite codec pack Full found on : http://www.free-codecs.com/k_lite_codec_pack_download.htm
- remove media player (MPC-HC) http://i.imgur.com/KANyN7b.png
- remove Tools (codec tweak tool, mediainfo lite, graphstudionext) http://i.imgur.com/LJazJXo.png
- don't create a start menu folder http://i.imgur.com/5jyZtjm.png
- don't creat start menu shortcuts for codec configuration http://i.imgur.com/3pzRei1.png
- don't show tray icons http://i.imgur.com/6hbXKWk.png
- don't visit a website codec news http://i.imgur.com/MBDVxw3.png
- perform preferrd lang config (1r lang: Arabic, 2d lang: French, 3d lang: English) http://i.imgur.com/OQ3Eefs.png
- remove additional soft (adware) http://i.imgur.com/ewvgT3k.png
- silent install.
Thanks!
Silent install maker for KL Codecs/QT Alternative/Real Alternative packages
filename:KLite_silent_install_maker.7z
size:799 KB (818.994 bytes)
md5:A92DA79B2F5D3A41A8B998386682E806
How it works?
After extraction of 7z package, run KLite_silent_install_maker.exe and browse to yours codec package.
Follow MakeUnattended steps then wait finish message.
maker_No_shell_mediainfo.exe - modified maker that remove shell extension added by media info. (HKCR\*\shell\MediaInfo)
Source
@mooms Thank you!
  • 8 months later...
