Hi Liam,
in the new release same errors like this thread (manager empty after mount) and
this thread (WAIK 8.1 necessary, otherwise error!); WTK does not check if it's installed!
Installed in a VM, x64 italian, it takes the OS language if more are installed in "lang", but under "About" is en-US as language displayed, even if menus and texts are in italian.
New icons look good!
Thiersee
post-26665-0-13652000-1435061723_thumb.j
Edited by Thiersee
You need Dotnet 4.5
"Dotnet 4.5 kurulu olması gerekiyor, çalışmasında bir sorun yok. Ayrıca masaüstünde klasör açıp program çalıştırmanda ilginç."
