Posted July 8, 20159 yr Hello,Wondering if there is any way to modify win7 installationNeed to get a driver installed before choosing the disk you want it to be installed onThe W7 version I find SSD disk but can not be installed if I do not seek, and install driver for free_fal_sensorWant's so clear that it is automaticallyHope you understand what I mean
July 8, 20159 yr WinToolkit (and many other gui tools) has the option when integrating drivers to integrate boot critical drivers as well, or you can integrate your driver into boot.wim index #2 and this will solve your problem
July 8, 20159 yr Author On 7/8/2015 at 4:38 PM, ricktendo said: WinToolkit (and many other gui tools) has the option when integrating drivers to integrate boot critical drivers as well, or you can integrate your driver into boot.wim index #2 and this will solve your problemI use WinToolKit and used install.wimBut should try boot.wim thanks for the reply :-) Come on one thing, I need to have the driver No 1 Edited July 8, 20159 yr by Hans Jakobsson
July 8, 20159 yr The program will add them in both places (boot.wim and install.wim) in one go. Just tick the boxes in All-In-One Integrator > Options Tab under Drivers category.
July 8, 20159 yr Author On 7/8/2015 at 7:48 PM, ianymaty said: The program will add them in both places (boot.wim and install.wim) in one go.Just tick the boxes in All-In-One Integrator > Options Tab under Drivers category.thanks, but it works anyway not, the same problemis there any other way to get into the drivers, take some time to compilera about everything every time
July 8, 20159 yr Author now it is confused in my head :-)When I load onto win back and check on drivers so located that file I sparde the first place is not there, is there anything he chooses Annar it's me who does something idiosyncratic sorry for my english, use google translate :-) Edited July 8, 20159 yr by Hans Jakobsson
