Hi all,
I would like to know if it's possible to change the list of silent installers can be changed, after Wintoolkit has finished the job.
Restarting wintoolkit, is one way to adjust the runonce list.
The 2 files, WinToolkitRunOnce.exe & WinToolkitRunOnce.exe.config, are located in the install.wim system32 folder. I thought by adjusting the file "WinToolkitRunOnce.exe.config" I could change some minor settings. But these file doesn't show the list of installers.
Any suggestion?
