Download: MEGA
Product Name: Adobe Acrobat DC Pro
File Name: AcrobatDCPro1500820082.exe
Version: 15.008.20082 (Continuous)
Date: 7/31/2015
MD5: 53EBCFF436224BEEC4EC8B2E65AF9752
Tweaked:
Optimization: Disabled
Caching of installer files on local drive: Disabled
Configuring a Rights Management Server: Disabled
Configuring WebMail profile: Disabled
EULA: Accepted
Default Action for Unspecified File Types: Never Launch
Acrotray.exe runs at startup: Removed
Product Updates: Disabled
Upsell: Disabled
When launching PDF in IE: Prompt to open/save
Adobe Acrobat Document Could services: Disabled
Adobe Send for Signature: Disabled
Preference synchronization across devices: Disabled
Third party connectors such as Dropbox, Google Drive, etc.: Disabled
HideMenu.js: Inculded
Default Installation
Acrobat Language: OS Language
MSI Interface Language: OS Language
Desktop Shortcut: Disabled
Install Mode: Trial
Adobe Refresh Manager: Disabled
Work AnyWhere: Disabled
Acrobat documentation: Disabled
Manually check for and install updates
/ai2 - Default Installation (Silent)
Custom Installation
<AcrobatDCPro.exe> /ai3 [/q{n|b|r|f|n+|b+|b-}] [TRANSFORMS=Transforms\Lang_mst.mst] [PROPERTY=Valve]
/ai3 - Custom Installation
Lang_mst - The transforms will be applied for the msi and Acrobat language.
PROPERTY - The features and other Acrobat installation options.
Other command-line options for the Windows Installer can be applied:
https://msdn.microsoft.com/en-us/library/aa367988%28v=vs.85%29.aspx
The transforms will be applied for the MSI and Acrobat language if the following Lang_mst is specified.
Language                      Lang_mst
Arabic                            1025
Czech                            1029
Danish                           1030
German                         1031
English                          1033
Spanish                         1034
Finnish                          1035
French                           1036
Hebrew                           1037
Hungarian                      1038
Italian                             1040
Japanese                       1041
Korean                           1042
Norweigan                      1044
Dutch                             1043
Polish                             1045
Portuguese (Brazil)        1046
Russian                          1049
Slovak                            1051
Slovenian                       1060
Swedish                          1053
Turkish                           1055
Ukrainian                        1058
Chinese Simplified          2052
Chinese Traditional         1028
Screenshots
Tool for create installer
Acrobat Customization Wizard DChttp://www.adobe.com/support/downloads/detail.jsp?ftpID=5892%E2%80%8BInstEdhttp://www.wincert.net/forum/topic/9769-modded-insted-151526-lzx21/7zSDhttp://7zsfx.info/en/download.html
Edited by alan_fox
Sorry but we do NOT allow warez! (patch.cmd)
RunProgram="hidcon:cmd /c for /f \"skip=1\" %i In ('wmic os get oslanguage') Do AcroPro1500820082.msi TRANSFORMS=Transforms\%i.mst DISABLE_MODE_SELECTION_OPTION=YES DISABLE_ARM=YES DISABLE_HELP=YES DISABLE_DTSHORTCUT=YES DISABLE_WORK_ANYWHERE=YES INSTALL_MODE=TryOut HIDELAUNCHBUTTON=YES UPDATE_MODE=0 & Exit"RunProgram="hidcon:patch\patch.cmd & cmd /c exit"AutoInstall2="AcroPro1500820082.msi"AutoInstall2="hidcon:patch\patch.cmd & cmd /c exit"AutoInstall3="AcroPro1500820082.msi";!@InstallEnd@!
warez removed. patch.cmd is not the warez, the warez is the dll file.
Is repack installer warez if it included copyrighted material (applications)? ( I read this.)
Edited by alan_fox
