Posted August 24, 20159 yr I would like to know, if it's wise to use WTK to use the feature of creating a ISO file and rebuild the W10 image? I need to be sure, I don't like the idea that the install.wim is corrupted after this rebuild process.
August 27, 20159 yr I would like to know, if it's wise to use WTK to use the feature of creating a ISO file and rebuild the W10 image? I need to be sure, I don't like the idea that the install.wim is corrupted after this rebuild process.Works fine for me...Regards... ;-)
