Posted (edited)
What's the bare minimum updates you need to integrate to bring a Windows 7 64bit SP1 up-to-date (No downloads show using Windows Update)? Do I need to only integrate Hotfix and Security updates or only General and Security updates or only Security updates? Is there a bare minimum update pack to download that a member or someone has created?
I'm looking to create an up-to-date Windows 7 SP1 with all the driver packs integrated.Thanks in advance for any help!
Edited by djkilla
  • 6 months later...
7 hours ago, Bdog4life said:
Where did this topic go? I am in need of a new up to date windows 7 update list
While the link that @dareckibmw provided lists a good number of essential application repacks for a complete Windows 7 install, some of which can also be found here at WinCert, for the up to date windows 7 update list, I think that dareckibmw meant to give you this link - http://www.wincert.net/forum/index.php?/topic/12103-20-avril-2016-update-list-gdr-pour-windows-7-sp1-x86x64-fr-en-de-es-it/
which is the updated link of what was referred to in response to the OP.
Posted (edited)
No, I meant Ricktendo's repacks. Since Bdog4life posted directly below my most, I assumed he asked me. And those links I posted doesn't work anymore. Anyways.....he should be set with all that now. ;)
Edited by dareckibmw
icare maintains a repack of .Net 4.6.1 here:
French LP is integrated but only installed on French system, so anyone can use it.
Posted (edited)
MS just released rollup update - https://support.microsoft.com/en-us/kb/3125574
Quote
... This rollup package includes almost all the updates that were released after the release of SP1 for Windows 7 and Windows Server 2008 R2, through April 2016. This convenience rollup is intended to make it easy to integrate fixes that were released after SP1 for Windows 7 and Windows Server 2008 R2. We recommend that you include this rollup package in the image creation process to make it easier to quickly set up a computer.
Download via IE (support for others browsers will be added later):
http://catalog.update.microsoft.com/v7/site/Search.aspx?q=3125574
Edited by Jankes
