Posted October 31, 20159 yr Download: RGhost Product Name: Recuva File Name: recuva-dual-setup-1.52.1086.exe Version: 1.52.1086 (x86/x64) Size: 3.17 MB Date: 11/1/2015 MD5: 13B1AD420442D93D0CA66025ED179B61 Virus Scan Result: VirusTotal Tweaked: Disable Automatically check for update to Recuva Disable Desktop Shortcut Disable 'Scan for deleted files' option to Explorer context menu Disable 'Scan for deleted files' option to Recycle Bin context menu Added: Recuva installation options (Run with /? to show) Example: Install Free Edition, no extraction dialog and with desktop icon. <recuva-dual-setup.exe> /ai /gm2 DESKTOPSHORTCUT=1Install Profressional Edition, custom installation directory and registered with your license. <recuva-dual-setup.exe> /ai2 INSTALLDIR="D:\Recuva" NAME=WinCert.net KEY=XXXX-XXXX-XXXX-XXXX Edited November 1, 20159 yr by alan_fox
