rowers Posted November 13, 2015 Posted November 13, 2015 Hi. I would like to learn how to create a Windows 7 AIO with HB, HP, PRO, ULT. I was able to integrate updates, create a file Autounattend.xml based on this topic http://www.wincert.net/forum/topic/9178-create-your-own-autounattendxml-all-in-one-x86amd64/ Can you help me integrate the default keys, so that did not activate automatically, because then I would be able to change the key. I would also like to join installation, for example Chrome, WinRar. Thank you very much for your help Regards Quote
doomdorker Posted November 17, 2016 Posted November 17, 2016 It's not really worth it in my opinion. From my experience you have to let each set of updates slipstream into each single version and THEN end up with a big image. I did this a couple years back and just made me realize it wasn't worth repeating over and over every so often with a new set of updates every month. I would say you're better off just keeping an updated set of .msu's or whatever updates and then integrate into whatever version you need at the moment. btw, when I did do it it wasn't very hard. You just use Windows Toolkit and select ALL versions to integrate them into if I'm not mistaken (which I might be since it's been a while). Quote
