Hello,
I'm trying Win Toolkit to create a Win7 x64 image with integrated updates.
The first issue, however, is that neither my Dvd, nor a downloaded official Win7 iso appears in it.
(see img. I've also tried my user folder)
Is this normal? I'm using Vista x86: could this be the problem?
(Dism is installed)
I've also noticed other errors:
- the program freezed while copying the dvd files to the hdd (I had to do it manually). :o
- it randomly crashed too.
- the temporary key suggested to get the official iso didn't work (but I already had one).
post-56053-0-49738900-1449875057_thumb.p
Edited by phaolo
That sounds more like a memory issue. Is the ram ok? Do you have lots of free space on the working drive?
I didn't have any problems with the memory and 3\4 of the disk is empty.
Maybe I'll try the program on a x64 pc with Win8.1.
It works on Win8.1 x64: it must be a Vista problem.
Btw, is it true that the KB patches must be ordered (how?) manually for a correct integration? O_o
Also, where can I find info about the various Tweaks?
I wish that the right panel could contain more explanation and maybe a copiable command too (eg: reg path).
Edited by phaolo
  • 4 months later...
Similar issue here. Using Vista (32) and have the .wim file correct, but no image name populates. Have messaged the creator to see if this will get resolved.
Although I messaged the creator to see if this could get resolved, nothing has come of it. I moved on and used RT7Lite to accomplish the task, and I recommend RT7Lite. If you use RT7Lite (free download is available), be sure that if script error messages (usually 1 or 2) come up and ask if you want to continue script running on the page to select "yes" or I understand that the options selected might not actually get recorded. Too bad Win Toolkit (1.5.4.4) did not work. Also, for making a bootable USB drive, the Windows Download USB/DVD tool worked very well after including the missing bootsect.exe file (there are youtube videos that are effective in showing this simple resolution).
Cheers
Edited by beauPC
