Posted January 9, 20169 yr Hello again :). I saw if i select All-in-One Disk Creator and i select any .wim file it shows me dialog with this: can someone help me? Thanks. Edited January 9, 20169 yr by MorcCrafak
January 9, 20169 yr May be your wim is damaged: .SWM-files are normally parts of a .wim-file and are read-only. Were did you get this .wim-file from? From wich OS? Regards, Thiersee Edited January 9, 20169 yr by Thiersee
January 9, 20169 yr Author I tryed mine windows 7 edited in other software and original windows 8.1 enterprise .wim file
January 9, 20169 yr 5 minutes ago, MorcCrafak said: I tryed mine windows 7 edited in other software and original windows 8.1 enterprise .wim file I tried just now with version 1.5.4.4 and Win7: no problem; regardingfor Win 8.1 no idea. But one thing I know for sure: you should not work with different programs on the wim-file. Thiersee
January 26, 20169 yr On 9. 1. 2016 at 9:48 AM, MorcCrafak said: Hello again :). I saw if i select All-in-One Disk Creator and i select any .wim file it shows me dialog with this: can someone help me? Thanks. Did you unticked the read-only mark in WIM properties? Try to reexport image by DISM:(the names are just an example) Before this you should prepare 6+GiB of space. Dism /Export-Image /SourceImageFile:install.wim /SourceIndex:1 /DestinationImageFile:install2.wim /Compress:none I don't know other solutions. Edited January 26, 20169 yr by TTtie
