Posted January 11, 20169 yr So the runonce installer requires the iso to be mounted in windows to run right after installation? Since I want to use easyboot multi os bootloader, this then stops it from running. Is it possible to make it so the installer is copied to hdd during the copy files stage and then doesnt require the iso to be mounted? Also is it a known issue (on 1.x) that it seems to sit on please wait forever in windows 8.1?
