Posted February 16, 20169 yr Source: drp16.2.zipReleased: 09-Feb-2016Homepage: DRPAbout: Designed to simplify the driver installation and updating process to a couple of clicks. Removed: - autorun.ini - DrvUpdater.exe - Translation files - Programs list inside Settings.js, except PhysX - replaced old CPU-Z with latest version - rebuild Backuper\Packer without Adware Tweaked: - Disable Restore Point inside config.js --> restorePoint = false; - Disable Automatic Update inside config.js --> autoUpdate = false; Added: - PhysX AiO installer [Inno Setup] inside Soft folder File: drp16.2_mod+physx.zipSize: 57,6MBMD5: 99185C997FA261D078766CD419D6E26ADownload: https://www.mediafire.com/?2fpafvo7c6eomvc Edited February 21, 20169 yr by kanyos
February 21, 20169 yr Author Fix: - fixed Settings.js cannot detect PhysX 9.15 registry - updated Inno Setup 5.5.8 to disable WelcomePage PhysX installer
April 2, 20168 yr On 25/02/2016 at 0:12 AM, Docthal said: not working can't update driver need download dvd version 1. First you need to download DriverPack Solution (iso / 10,2 Gb) from https://drp.su/ 2. Edit iso image and replace existing files and folders and keep onely "Drivers" folder. @kanyos Can you explain me how to rebuild dps without Adware? Edited April 2, 20168 yr by SMed79
April 15, 20168 yr Be careful with original downloaded stuff from drp.su. When you install this stuff, it will also install a lot of unnecessary crap
April 15, 20168 yr You have to uncheck the apps as they are checked by default or what I do is grab the driver packs themselves from the folder and use my silent method to run them instead of using their installer app
April 15, 20168 yr Thanks Kirk, I had this experience some time ago. There wasn't any uncheck possible.
