Posted July 7, 200717 yr Hi there......I have seen many screenshots of VTP and I like it very much, but I don
July 7, 200717 yr Get Virtual PC, and install a copy of XP inside it and test out the pack. It's the safest way to test it (other than loading it up on a fresh install of XP on your computer).
July 8, 200717 yr Author Get Virtual PC, and install a copy of XP inside it and test out the pack. It's the safest way to test it (other than loading it up on a fresh install of XP on your computer).Ok thanks guys........I
August 1, 200717 yr VTP7 is fine i have it and i have had no problemsjust install it in safe mode thats the only way the installer will run
August 1, 200717 yr VTP7 is fine i have it and i have had no problemsjust install it in safe mode thats the only way the installer will runYup I heard that too...the only thing I don't like on VTP7 is the Thoosje Sidebar. The RTM sidebar is much better :thumbsup_anim:
