Posted February 29, 20169 yr I have a disk with all versions of Windows 7, both 32-bit and 64-bit. When I make the integration of updates into one of them (eg Windows 7 Professional 32-bit) and create the ISO, the resulting disk is installed without any problems. But when I make integration of all 32-bit versions, the resulting disc always gives an error in the last phase of the installation. Why when I integrate one of them works but integrating in all fails?. Thank you.
February 29, 20169 yr raist, try not to mix 64bit updates and 32bit operating system Edited February 29, 20169 yr by digital john
February 29, 20169 yr Author No I don't mix, the original disc have all windows 7 versions, but when I integrate the updates only select x86 versions. I'm selecting only 32 bits updates but when I integrate in all 32 bits versions the ISO install fails. If I integrate the same updates into one version the ISO install success.
February 29, 20169 yr Author Some news, I integrated one update in one version (windows 7 Starter 32 bits), rebuilded and recreated ISO. If I install this version the installation success but, if I try to install windows 7 Professional 32 bits the installation fails in the same point. Anyone knows what can be the problem, because I'm dont know anything!
March 4, 20169 yr You're using a illegal source of windows seven. Any further questions about this iso will result in you being banned. MS Windows seven images did not come in dual 86 & 64 format. Any arguments with this decision will get you banned also.
March 4, 20169 yr Hi Kel, It's not my intention to argue with your decision, but he could have put all the single ISOs together with WinToolkit... @raistlin2912 Where did you get the disc with all the versions? Thiersee Edited March 4, 20169 yr by Thiersee
March 6, 20169 yr On 3/4/2016 at 4:05 PM, Thiersee said: Hi Kel, It's not my intention to argue with your decision, but he could have put all the single ISOs together with WinToolkit... @raistlin2912 Where did you get the disc with all the versions? Thiersee The reason I am so sure he is using a warez release is that nowhere does he ever mention "I tried the original x86 or x64 iso" I see lots of "I did just this version from the iso" or "I tried only these versions"
