Posted March 29, 20168 yr Hello, i installed the latest WinToolKit Version (1.5.4.4) to integrate Updates to my Windows 7 Image. The Integration worked without any error. After Installation of the new Windows 7 Image, the Windows Update Agent says there are Updates available to install. But all available Updates are Updates, who where integrated successfully. (ca. 76, e.g.: KB3134814) I mounted only the Windows 7 x64 Pro Image to integrate the Updates, because I only install the Pro Version of Windows 7. Do you have any idea to solve the problem? Best regards Karl der Heinz
March 30, 20168 yr Windows Updates will always show some updates to install. Mostly are superseded and not needed. You can safely hide them or you can install them to shut up WU.
March 31, 20168 yr Author 13 hours ago, ianymaty said: Windows Updates will always show some updates to install. Mostly are superseded and not needed. You can safely hide them or you can install them to shut up WU. Shure? But most of them are Security Updates. I don´t think this Updates are unimportant.
March 31, 20168 yr Quote ..... (ca. 76, e.g.: KB3134814) Kb3134814 (IE11) is superseeded by kb3139929. You can check the status of every Kb under catalog.update.microsoft.com.
