images?q=tbn:ANd9GcS--UTSynYftnrr2jgXIRA
Foxit Reader v7.3.4.311 - Slim RePack
Quote
Foxit Reader is a lightweight, fast, and secure PDF Reader capable of high-volume processing.
ModificationsRemoved many useless plugins (google drive plugin, facebook plugin, docusign plugin, foxit cloud plugin etc.), & improved the compression, to make it a very-simple pdf reader. Decreased file size from 40.9 MB to 23.9 MB (17 MB decreased). Not Working: Foxit PDF Printer/Creator is not getting installed. :( Sorry for that. I just couldn't get it to work. If needed you can install BullZip PDF Printer from here
Optional Command-Line Switches:
Quote
/SILENT: Passive installation, shows only installation progress. NO user input required. Installs ALL packages.
/VERYSILENT: Fully silent installation, shows no GUI at all. NO user input required. Installs ALL packages.
/NORESTART: Prevents setup from restarting after a successful installation.
/SUPPRESSMSGBOXES: Instructs setup to suppress(remove) message boxes. Only effective when used with /SILENT or /VERYSILENT switch.
Examples: For a completely silent install, without any error pop ups/progress, use: /VERYSILENT /NORESTART /SUPPRESSMSGBOXES /SP- ; For installation without any user input, no error boxes, only progress window: /SILENT /NORESTART /SUPPRESSMSGBOXES /SP-
DOWNLOADMega  | File Name:  FoxitReader_7.3.4_RePack.by.niT€_RiDeR_Pr0.exe.exe | File Size: 23.9 MB
File Hashes/Checksums: http://pastebin.com/6u3KkmUE
  • 3 months later...
  • 5 years later...
