Bonjour
J'ai voulu refaire un nouveau DVD d'installation de Windows Seven 32 bits
après intégration des mises à jour, réglages divers
je lance et j'obtiends ceci :
Starting
Tool Name: All-In-One Integrator (3 Images Selected)
Image Name: Windows 7 HOMEPREMIUM
WIM File: C:\S32_extract\SOURCES\install.wim
Mount Logging: True
Drive Type: Fixed
Free Space: 103.73 GB
IsReady: True
File Exists: True
File Size: 1.96 GB
Directory Exists: True
Files:
Directories:
Logging: "C:\Program Files (x86)\WinToolkit\Logs\Mount_Logs\Windows_7_HOMEPREMIUM_10442.log"
TempDir (True): C:\Windows\WinToolkit_Temp\MountTemp_49042E1BCBD7C1FC9C59C0397ACE8C64
FileName: "C:\Windows\WinToolkit_Temp\Files\Imagex.exe"
Argument: /mountrw "C:\S32_extract\SOURCES\install.wim" 1 "C:\Mount_9FA211C895D40EC69A9BE40570359BA8" /logfile "C:\Program Files (x86)\WinToolkit\Logs\Mount_Logs\Windows_7_HOMEPREMIUM_10442.log"
Setting taskbar Progress
Setting taskbar Colour
Dumping Registry
Starting
Started
Output: ImageX Tool for Windows
Output: Copyright (C) Microsoft Corp. All rights reserved.
Output: Version: 6.2.9200.16384
Output: Mounting: [C:\S32_extract\SOURCES\install.wim, 1] -> [C:\Mount_9FA211C895D40EC69A9BE40570359BA8]...
Output: [   0% ] Mounting progress
Output #1: [   0% ] Mounting progress
Output #2: [   0% ] Mounting progress
Output #3: [   0% ]
Output #4:
Writing Status T: [   0% ] | PT:
Done Status
Writing Taskbar
Done Taskbar
Output: Error mounting image.
Output: Le chemin d’accès spécifié est introuvable.
Closing #0
Closing #1
Closing #2
Finished
De quel chemin d'accès est-il question à la fin du LOG ?
Merci d'avance
P.S. : j'ai testé avec le 64 bits & même message d'erreur :(
Edited by five1966
