Posted May 17, 20168 yr Rufus 2.11 Build 995 [ Create bootable USB drives easily ]Rufus is a small utility that helps format and create bootable USB flash drives, such as USB keys/pendrives, memory sticks, etc. It can be be especially useful for cases where: you need to create USB installation media from bootable ISOs (Windows, Linux, etc.); you need to work on a system that doesn’t have an OS installed; you need to flash a BIOS or other firmware from DOS; you want to run a low-level utility. Rufus is significantly faster than similar utilities and it’s open source and free. All versions of Rufus allow the creation of a bootable USB from an ISO image. Creating an ISO image from a physical disc or from a set of files is very easy to do however, through the use of a CD burning application, such as the freely available CDBurnerXP or ImgBurn. This app requires admin rights. Despite its small size, Rufus provides everything you need! Rufus is fast. For instance it’s about twice as fast as UNetbootin, Universal USB Installer or Windows 7 USB download tool, on the creation of a Windows 7 USB installation drive from an ISO. It is also marginally faster on the creation of Linux bootable USB from ISOs. Rufus support UEFI as well as GPT for installation media, meaning that it will allow you to install Windows 7, Windows 8 or Linux in full EFI mode.However, Windows Vista or later is required for full UEFI/GPT support. Because of OS limitations, Windows XP restricts the creation of UEFI bootable drives to MBR mode. Supported Languages: :Bahasa Indonesia ,Bahasa Malaysia ,Български ,Dansk ,Deutsch ,Ελληνικά ,English ,Español ,Français ,Hrvatski ,Italiano ,Latviešu ,Lietuvių ,Magyar ,Nederlands ,Polski ,Português ,Português do Brasil ,Русский ,Română ,Slovensky ,Slovenščina ,Suomi ,Svenska ,Türkçe ,العربية ,简体中文 ,正體中文 ,日本語 ,한국어 . Created by VandIT Rufus 2.11 Build 995 Silent + Portable Quote http://tigerfiles.net/file/1473358050_Rufus211http://gavitex.com/share/dpiy3rnpvhttps://www.solidfiles.com/v/nNj4Q5gKzAQv7 Thanks you Vandit For Installer Edited September 8, 20168 yr by geodasoft
July 20, 20168 yr Author Changes in Rufus 2.9 (2016-05-17): Add ARM support for UEFI:NTFS Fix UEFI:NTFS support for some HP and Gigabyte platforms (with thanks to Rod Smith and linnaea) Fix unwanted listing of some internal removable drives Fix the resurgence of a possible Syslinux installation crash Fix missing default cluster size default on exFAT for >32GB drives Fix the non-removal of the commandline hogger in some corner cases Use “modern” file selection dialog on Vista or later (if you can spot the difference, good for you…) Changes in Rufus 2.10 (2016-07-20): Add SHA-256 validation for downloaded files. You will now see an ✓ or ✗ in the log for relevant content Add support for O2Micro PCI-E card readers Add compressed NTFS support for UEFI:NTFS Improve automatic closure of the Windows default format prompt Improve support for Ubuntu, Springdale and Antergos (Syslinux version detection) Work around a Windows bug that can render a GPT disk inaccessible after cleanup (e.g. ChromeOS image) Fix hash computation for content that isn’t a multiple of 64 bytes Fix Syslinux installation on some media Fix a corner case where settings could be altered after Start had been pressed, if a hotplug event also occurred Additional fixes and improvements
September 8, 20168 yr Author Changes in Rufus 2.11 (2016-09-08): Do not download BIOS related files unless BIOS boot is selected Improve support for Arch Linux derivatives Add a cheat mode to disable drive indexing (Alt-Q) on format Fix handling of ‘Super Floppy Disk’ formatted drives Fix handling of misleading short write reports for drives larger than 1 TB Fix an issue that enabled FAT32 file system selection on some Windows images Fix broken UI font for XP users Fix sanitizing of exFAT labels
