Tristis Oris Posted May 18, 2016 Posted May 18, 2016 can't integrate new KB3125574. clean msdn image. Spoiler An error occurred whilst integrating an update! Exception: Microsoft Windows [Version 10.0.10586] (c) 2015 Microsoft Corporation. All rights reserved. D:\WinToolkit_1.5.4.4> chcp 65001 D:\WinToolkit_1.5.4.4>Set SEE_MASK_NOZONECHECKS=1 D:\WinToolkit_1.5.4.4>"C:\WINDOWS\System32\Dism.exe" /Image:"C:\WinToolkit_Mount_39BB7AFEF878BA86A4421AFCE76C14F7" /Add-Package /PackagePath:"D:\[Download]\ISO_clean\Update for Windows 7 for x64-based Systems (KB3125574)\AMD64-all-windows6.1-kb3125574-v4-x64_2dafb1d203c8964239af3048b5dd4b1264cd93b9.msu" /ScratchDir:"C:\WINDOWS\WinToolkit_Temp\ScratchDir_3438B83678BDFFC6F623AE05E9A33AD3" /English Deployment Image Servicing and Management tool Version: 10.0.10586.0 Image Version: 6.1.7600.16385 Processing 1 of 1 - Adding package D:\[Download]\ISO_clean\Update for Windows 7 for x64-based Systems (KB3125574)\AMD64-all-windows6.1-kb3125574-v4-x64_2dafb1d203c8964239af3048b5dd4b1264cd93b9.msu [ 0.0% ] [ 0.7% ] [ 1.7% ] [= 2.6% ] [== 3.6% ] [== 4.6% ] [=== 5.6% ] [=== 6.6% ] [==== 7.6% ] [===== 8.6% ] [===== 9.6% ] [====== 10.6% ] [====== 11.6% ] [======= 12.6% ] [======= 13.6% ] [======== 14.6% ] [========= 15.6% ] [========= 16.6% ] [========== 17.6% ] [========== 18.6% ] [=========== 19.6% ] [=========== 20.6% ] [============ 21.6% ] [============ 21.6% ] [============ 21.6% ] [============ 21.7% ] [============ 21.7% ] [============ 22.0% ] [============ 22.2% ] [============ 22.2% ] [============= 23.2% ] [============== 24.2% ] [============== 25.1% ] [============== 25.1% ] [============== 25.1% ] [============== 25.2% ] [============== 25.2% ] [============== 25.2% ] [============== 25.2% ] [============== 25.3% ] [============== 25.4% ] [============== 25.4% ] [============== 25.8% ] [============== 25.8% ] [============== 25.8% ] [============== 25.9% ] [=============== 25.9% ] [=============== 25.9% ] [=============== 25.9% ] [=============== 25.9% ] [=============== 26.0% ] [=============== 26.0% ] [=============== 26.0% ] [=============== 26.0% ] [=============== 26.1% ] [=============== 26.2% ] [=============== 26.6% ] [=============== 26.6% ] [=============== 26.7% ] [=============== 26.7% ] [=============== 26.8% ] [=============== 26.9% ] [=============== 26.9% ] [=============== 26.9% ] [=============== 27.0% ] [=============== 27.1% ] [=============== 27.1% ] [=============== 27.4% ] [================ 27.8% ] [================ 27.8% ] [================ 28.3% ] [================ 28.4% ] [================ 29.1% ] [================= 29.8% ] [================= 30.3% ] [================= 30.4% ] [================= 30.4% ] [================= 30.4% ] [================= 30.4% ] [================== 31.4% ] [================== 31.8% ] [================== 32.0% ] [================== 32.2% ] [================== 32.3% ] [================== 32.6% ] [=================== 32.9% ] [=================== 33.0% ] [=================== 33.0% ] [=================== 33.0% ] [=================== 33.2% ] [=================== 33.3% ] [=================== 33.3% ] D:\[Download]\ISO_clean\Update for Windows 7 for x64-based Systems (KB3125574)\AMD64-all-windows6.1-kb3125574-v4-x64_2dafb1d203c8964239af3048b5dd4b1264cd93b9.msu: An error occurred applying the Unattend.xml file from the .msu package. For more information, review the log file. Error: 0x800736b5 Error: 14005 The manifest file contains one or more syntax errors. The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log D:\WinToolkit_1.5.4.4>exit ---------------------------------- Quote
Guillermo Riquelme Posted May 18, 2016 Posted May 18, 2016 To apply this update, you must install the April 2015 servicing stack update for Windows 7 (KB3020369). You can read more about the Convenience rollup update for Windows 7 SP1 here. Quote
Ricardo Silva Posted May 18, 2016 Posted May 18, 2016 same error. Wintoolkit warns that isn't a update to integrate. i ignored, added the KB3020369 and KB312557. On my first try in x64 clean image, success. After 3 tries in x86 image, also suceeded. But unnfortunnaly, Windows 7 updates are slow and takes forever to get the updates list. I will continue to test... Quote
Tristis Oris Posted May 19, 2016 Author Posted May 19, 2016 tried few times. KB3020369 firstly, KB3125574 second. toolkit always crashes in the middle of work. X-Force 1 Quote
filter Posted June 1, 2016 Posted June 1, 2016 Add this updates to Win Toolkit. Right click in kb3020369 change it to PREREQUISITES. Right click in kb3125574 change it to UPDATES. Works to me dareckibmw and Tristis Oris 2 Quote
Tristis Oris Posted June 2, 2016 Author Posted June 2, 2016 good solution. looks like it works now. it remains to verify the image. Quote
sweden8 Posted June 2, 2016 Posted June 2, 2016 (edited) "Right click in kb3020369 change it to PREREQUISITES. Right click in kb3125574 change it to UPDATES." It works, but you get a big load of updates afterwards. And I feel that I have very little knowledge or control of what is in kb3125574. I will stick to the traditional manual updatepicking for now... Edited June 2, 2016 by sweden8 Quote
filter Posted June 2, 2016 Posted June 2, 2016 kb3125574 have all updates from sp1 to april 2016 except net framework 3.5 & internet explorer updates. net framework 3.5 updates missing is in photo. also missing internet explorer 11 & updates for ie Quote
gamer388 Posted July 23, 2016 Posted July 23, 2016 (edited) Hey, I wanted to make an ISO of win 7 pro 64bit SP1 with all the new updates. But when I try to integrate the KB3125574 I got an error and nothing is done. Here is the error log generated by Wintoolkit : Title: 2 error(s) have occurred ErrType: Error Description: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'. Exception: Error Integrating Update Exception: ---------------------------------- An error occurred whilst integrating an update! Exception: Microsoft Windows [version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. Tous droits r�serv�s. C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable>chcp 65001 C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable>Set SEE_MASK_NOZONECHECKS=1 C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable>"C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe" /Image:"C:\WinToolkit_Mount_BC0D1D187129DF0E664357E551EE1C48" /Add-Package /PackagePath:"C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable\Updates\Windows7-x64\General\Windows6.1-KB3125574-v4-x64.msu" /ScratchDir:"C:\Windows\WinToolkit_Temp\ScratchDir_787C3864C0D3BC91038C1F578CF835FC" /English Deployment Image Servicing and Management tool Version: 6.3.9600.16384 Image Version: 6.1.7600.16385 Processing 1 of 1 - Adding package C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable\Updates\Windows7-x64\General\Windows6.1-KB3125574-v4-x64.msu C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable\Updates\Windows7-x64\General\Windows6.1-KB3125574-v4-x64.msu: An error occurred applying the Unattend.xml file from the .msu package. For more information, review the log file. Error: 0x800736b5 Error: 14005 DISM failed. No operation was performed. For more information, review the log file. The DISM log file can be found at C:\Windows\Logs\DISM\dism.log C:\Users\Cyrille\Downloads\WinToolkit_1.5.4.1_Portable>exit ---------------------------------- Edited July 23, 2016 by gamer388 Quote
gamer388 Posted July 23, 2016 Posted July 23, 2016 (edited) On 19/05/2016 at 1:18 AM, Ricardo Silva said: same error. Wintoolkit warns that isn't a update to integrate. i ignored, added the KB3020369 and KB312557. On my first try in x64 clean image, success. After 3 tries in x86 image, also suceeded. But unnfortunnaly, Windows 7 updates are slow and takes forever to get the updates list. I will continue to test... I got the same problem with KB3020369. How do you add this KB without silent installer ? Edited July 23, 2016 by gamer388 Quote
f483755 Posted September 22, 2017 Posted September 22, 2017 Download Convenience Rollup (KB3125574) for Windows 7 32 bit: removed 64 bit: removed Please do not pots links with URL shortener or other scam sites, especially when it's a Microsoft file that can be downloaded from their servers. KB3125574 can be downloaded from Microsoft here http://www.catalog.update.microsoft.com/Search.aspx?q=KB3125574 Quote
