So hello guys, been a long time...:D
Some of us might still using Xp in daily use.
Long story short, I created an advanced transformation/customization pack for windows XP,
This pack bring some cosmetics change which only available on vista and later operating system. And also some other interesting customization.
you can see what this pack modifies in galleries below:
Gmusp5wm.jpg73U2A6Lm.jpg3s0MaZXm.jpg0NmDkScm.jpgoBSB04lm.jpggQyxGUim.jpgmMW98PWm.jpgG0eqLG0m.jpguL4u7vQm.jpgRozT6AQm.jpg7F2Nmn8m.jpg
Download Here
Instruction how to install is inside the archive: readme.txt. you should read it.
If you like it, use it, and want to support the development consider a Donation.
Edited by Dubby
Update with new version
On 6/30/2016 at 7:43 PM, luis said:
Hello Dubby, I'm glad to see you again around here, greetings
yep, Many things had happen in real life :D
On 8/6/2016 at 8:08 PM, Dibya said:
thanks
windows xp lives forever
you're very welcome.
oh btw I updated the pack.
  • 1 year later...
I am Still wondering if following features can be ever added:
* Search option to taskbar and startmenu
*Auto Changing wallpaper
Init setting.exe has subsystem version issue . It is set to vista.
For me Wypack doesnot work
