Hello.guys.i.can.not.open.exe.file.in.my.windows.so.please.i.need.help.only.i.can.open.exe.file.as.admin.but.some.time.i.can.open.exe.file.sorry.for.bad.english.becuse.some.keys.not.worked.on.my.keyboard!
Posted (edited)
i can't format my pc again because i don't want this and really i don't have any virus or malware on my pc because i formated my pc before some days!
so please any ideas to fix this i try to edit exe key in regedit and it's not worked!
Edited by wincert.net
I had this issue at one of my clients.
Probably "IsShortcut" string value for LNK filetype is missing in Windows Registry which could be removed by a Virus.
Open regedit and navigate to the following key:
HKEY_CLASSES_ROOT\Lnkfile
In right pane, right-click on empty area and select New -> String Value option.
Name it IsShortcut.
Close Registry Editor and restart your machine.
I've seen AVG antivirus cause this symptom in my Windows 10 installation. Looks like you're on Windows 7 but try and consider whether or not it's a combination of AVG and anything else you're using.
