ricktendo Posted July 9, 2007 Posted July 9, 2007 (edited) Blue XP Task Manager for Windows XP SP3 v5.1.2600.5512 by lsdmeasap Updated for SP3 May 10-08Website: http://www.aeroxp.org/board/index.php?showtopic=9258 Edited December 30, 2008 by *Reaper* Quote
Gorki Posted July 9, 2007 Posted July 9, 2007 Really cool stuff! I was getting bored from green Task Manager. :icon_cool: Quote
ScOOt3r Posted July 9, 2007 Posted July 9, 2007 sweet.. i like the look of this.. thanksScOOt3r Quote
Gorki Posted August 14, 2007 Posted August 14, 2007 ...and patched sp3 v3180 build.... :crying_anim02: Quote
ricktendo Posted October 5, 2007 Author Posted October 5, 2007 How to patch it ?You dont... This is for use with nLite Quote
hicko Posted May 8, 2008 Posted May 8, 2008 good morning all the world I search French sil taskmgr.exe xp sp3 you plait Quote
winxp Posted May 8, 2008 Posted May 8, 2008 good morning all the world I search French sil taskmgr.exe xp sp3 you plait+1 Quote
ricktendo Posted May 8, 2008 Author Posted May 8, 2008 This is what i gotHello m8, love your name (lsd me )Was wondering if you could be so kind and share the locations and values of the location for your Vista and XP task managers?I wanna update my own for XP SP3 and Vista SP1...I would greatly appreciate ittiaRickIt is not that simple. And I have not done SP3 or 64 so I could not even say. Long hours of trial and error is how you do it. I use XVI32 and Resource Tuner. All you can do is hex edit one color code save and apply, then check to see if it changed. Ohh, take a picture of each address each time you change it, so you can know to skip next time. Change one then check, if all good, keep image and name it what section it changed. Then toss that taskmanager, edit a new one and skip that first address and move on to the next color, change, test, delete, get new, on to the third address. That is the best way to do it because if you keep editing the same edited one you may change something incorrect and not notice. Then once you have them all changed and have images of each address get a new taskmanager and make all edits at once. Then in resource tuner or whatever you want to use, do the icon changes. Here is where I got my hex colors>>>http://www.december.com/html/spec/color3.htmlXVI32http://www.chmaas.handshake.de/delphi/freeware/xvi32/xvi32.htmJust a heads up, it will take you at least a hour or two for sureHey, here is my older images, but they will not be the same. I am just showing you so you get the idea of how I mean to do itImages download (These were XP addresses)>>>http://www.mediafire.com/?xdlddeyl2ydM34n already made x64 SP! if you need it here>>>http://m34n.deviantart.com/art/Blue-Taskmgr-for-Vista-SP1-x64-83564234 Quote
MrNxDmX Posted May 9, 2008 Posted May 9, 2008 (edited) Ooops, i've checked sp3 taskmgr file and the hex adresses doesnt match. Wow, really hard to find which one is for colour. lsdmeasap have done a great job on first release.Edit: I've finished my turkish sp3 one. Working perfect. But after putting the patched file in system32, windows errors started. DEP shuts explorer.exe down. I dunno the reason... Edited May 9, 2008 by MrNxDmX Quote
ricktendo Posted May 10, 2008 Author Posted May 10, 2008 Updated for SP3Any of the previous requests for this to be modded I wanna report that I can do it nowPlz upload your taskmgr.exe from your Windows XP and I will see what I can do Quote
hicko Posted May 10, 2008 Posted May 10, 2008 Updated for SP3Any of the previous requests for this to be modded I wanna report that I can do it nowPlz upload your taskmgr.exe from your Windows XP and I will see what I can doXP Task sp3 french veiled minehttp://www.zshare.net/download/1180637162848aa1/ Quote
ricktendo Posted May 10, 2008 Author Posted May 10, 2008 Here is the french task manager (this is not a addon) Link updated@ EVERYBODY ELSE:The English taskmgr.exe has been updated, I seemed to have missed the Page File spike (it was still yellow) its fixed now plz redownload Quote
ricktendo Posted May 10, 2008 Author Posted May 10, 2008 :oops: Sorry guys I seemed to have forgotten the system tray icons... both french and english versions updatedFrench: http://www.mediafire.com/?x3dvvjqm0om (not a addon)English: http://www.wincert.net/forum/index.php?aut...amp;showfile=83 (AddOn) Quote
MrNxDmX Posted May 11, 2008 Posted May 11, 2008 Why dont u update exe's icon too? Also it has a yellow bar in networking tab. Its not your fault, some of the images modify same addresses... Quote
bluetalking Posted May 15, 2008 Posted May 15, 2008 Why dont u update exe's icon too? Also it has a yellow bar in networking tab. Its not your fault, some of the images modify same addresses...hi try the ettachementHex Tweaked Blue XP Task Manager sp3Ricks_BlueXP_SP3_taskmgr_TweakedAddon.7z Quote
MrNxDmX Posted May 16, 2008 Posted May 16, 2008 Thanks for your attention bluetalking, but i've done mine already Check it out here, it contains an alternative, light http://www.wincert.net/forum/index.php?showtopic=3460 Quote
