Posted February 12, 20178 yr Wintoolkit v1.5.4.8 keeps on crashing when I try to use the AIO integrater and apply changes when it finishes un-mounting an image it crashes screenshots and settings will be attached I'am also using one addon: the Directx_june2010 x86.WA Can someone veryfiy if this is a bug or is it some settings conflict Thanks for your help in advance Settings.txt Session save.ini Windows_7_Starter_x86_39156.log Windows_7_Starter_x86_72264.log
February 12, 20178 yr which windows version do u have? Before using wintoolkit always disable antivirus and make sure nothing else is running on the background. Als have enough space on your hdd
March 9, 20178 yr On 2017/2/12 at 0:23 PM, ZERO_XP said: Wintoolkit v1.5.4.8 keeps on crashing when I try to use the AIO integrater and apply changes when it finishes un-mounting an image it crashes screenshots and settings will be attached I'am also using one addon: the Directx_june2010 x86.WA Can someone veryfiy if this is a bug or is it some settings conflict Thanks for your help in advance Settings.txt Session save.ini Windows_7_Starter_x86_39156.log Windows_7_Starter_x86_72264.log 1.5.4.8 where to download?
March 9, 20178 yr 5 hours ago, pazu said: 1.5.4.8 where to download? You have now 1.5.4.10 here: http://www.wintoolkit.co.uk/Home/TestBuilds/
